engine wont turn over, help!! - Mustang Evolution
Old 03-20-2005, 05:55 AM   #1
fast64's Avatar
I finished wiring everything up, but the engine won't turn over. I can hear the solenoid pop open when i turn the key, but nothing from the motor. is it possible that that battery has enough of a charge to run headlights and other little electrical crap but not enough to engage the starter?
GO BRAVES
Old 03-20-2005, 08:17 AM   #2
MonteCitan's Avatar
answer to first question:
Yes
do you have a battery charger? try it..
if that's a no go.. try tapping the starter while you have someone holding the key to the on position
got good power/ground? my '89 once - headlights would work, radio would work.. go to turn key, everything died and nothing worked.. ended up being a battery cable with high resistance..
another possibility.. bad starter
another possibility, something blocking the engine (can you turn it over by hand?)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-20-2005, 10:48 AM   #3
start there then work your way though possible areas, dont skip stuff cuz that may very well be what it is.
Old 03-20-2005, 08:51 PM   #4
silverstangboy's Avatar
most likely a poor connection, grounding is important
consider too that if your building a tight motor that being out of time will cause it to not turn over very easy at all!
93 mustang notch
~450hp 331 stroker - Sold
Old 03-20-2005, 09:26 PM   #5
wiarumas's Avatar
yeah.. what they said.
Old 03-21-2005, 05:26 AM   #6
fast64's Avatar
i think tonight i am gonna clean all the grounds and run another ground from the engine to the frame.
GO BRAVES
Old 03-21-2005, 06:07 AM   #7
Danger Dude's Avatar
Still time to bail and get a nice convertible with tennis racket holders!!!
But if you are really having problems. Can you turn over the engine by hand with a wrench on the crank pulley bolt. If you can
Bad Starter solenoid
low battery
Bad ground connection
If you cant's
Wrong crank bearing size
Main caps switched up and in the wrong place.
Old 03-21-2005, 01:02 PM   #8
fast64's Avatar
low battery
If you cant's
i am assuming its something with the wiring, b/c this engine was running in great condition less than a month ago and i did nothing to it other than supercharger install, P/S and and a/c delete, and new oil pan/pickup.
GO BRAVES
Old 03-21-2005, 02:04 PM   #9
Bane-'s Avatar
uh I think the supercharger killed it so you should send it to me and Ill install it on my car for further observations
Old 03-21-2005, 02:32 PM   #10
MonteCitan's Avatar
a few other points ... you should have your main ground going to the engine, with a smaller lead going to the chassis... got that okay? okay, good... next point... do all your pulleys spin freely? (including SC pulley.. if ones locked up and the belts good, it may keep the starter from kicking over..) flywheel's unblocked, right?
(basically, can you turn the engine over by hand? that's key to knowing you're not screwed )
Interior Light Wont Turn Off ! scrimsmustang Pre-2005 V6 Mustang 26 05-10-2005 04:03 PM
Fog lights wont turn on whitev6stang03 Pre-2005 V6 Mustang 26 01-24-2005 05:34 PM
10:42 AM
