starter wont stop turning over car - Mustang Evolution
Old 07-08-2009, 09:39 PM   #1
Angry starter wont stop turning over car
ok so i just bought my car its a 87 gt ragtop, well one day it wouldnt start so i just used a screwdriver to jump the terminals to get the car started. it worked so i went and bought a new starter selinoid, i threw that in and went to the gas station. shut the car off came out went to start it and the starter stuck and kept cranking the car over i could not get the battery cable off so the starter fried.
went to napa bought a new starter and new starter selinoid put that in and thought everything was fine, but went to start it and the starter stuck and kept cranking my car over, i pulled the battery cable off and disconnected everything and put it all back together, and it was all good. but it happens about once every 2 weeks. so my question is why does this keep happening? i tested to see if it was the ignition doing it by taking off the wire for it and its not the ignition.
any help would be great. thanks
niteninja87 is offline   Reply With Quote
Old 07-08-2009, 10:43 PM   #2
OsirisGuy's Avatar
Re: starter wont stop turning over car
I can look at it as an electrical problem, either there is a constant (or rather an accessory/ignition) hooked up to the starter wire which may have been cause if you fooled around with some of the wiring (i.e. you ghetto rigged it) OR it could be a bad key (ignition) cylinder. Something on the inside is getting stuck when you turn the key so it sticks on the starter and keeps sending a signal.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-09-2009, 07:16 AM   #3
When it would stick, I would pull off the positive battery termminal so itd stop.(ie no power) but if I tapped the terminal with the battery cable itd crank again, it wouldn't stop till I took everything off the selinoid
Old 07-09-2009, 09:03 AM   #4
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
long shot, but is there different solenoids for that year/model :dunno:
i would probably go with osirisguy and say the key cylinder, i know those things mess up and can cause slews of problems.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-09-2009, 09:19 AM   #5
Herbstang's Avatar
Might want to give this site a look Mustang FAQ - Engine Information
Old 07-09-2009, 09:44 AM   #6
Scut95's Avatar
BTW, pull off the negative battery cable. It will do the same thing as pulling off the positive cable but it's safer to do.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 07-09-2009, 11:43 AM   #7
OsirisGuy's Avatar
To me it sounds more like the wiring to the starter is incorrect (or there is a connection between two wrong wires) or the key cylinder is bad. The cylinder shouldn't be too hard to replace but you might need new keys.
I'd also take a look at what Herb posted, man has plenty of useful info
OsirisGuy is right
2002 Mustang GT
Old 09-15-2009, 07:26 AM   #8
might be the key cylinder, might be th switch that the key ingages, little plastic on plastic pieces that have metal on each, that run across each other taped in a little aluminum cases that sometimes comes loose and causes the rod to come off that engaged it. hell, I have a brain fart and dont know anything yet except that my brain is fried from paint fumes. maybe by noon I can remeber what that part is that plugs in to the harness and attaches to the key cylinder.
brazin is offline   Reply With Quote
Car wont start iwannagofast 1996-2004 Mustang GT 3 03-03-2008 09:34 PM
STARTER WONT STOP. jesse4887 1979-1995 Mustang GT 5 11-09-2007 10:16 PM
Finished my install, try to start the car, starter is sluggish... Kiljosh Pre-2005 V6 Mustang 15 04-01-2006 09:26 PM
Car wont start!!! eNvy Pre-2005 V6 Mustang 5 04-29-2004 07:19 AM
Car wont start, help: Rellik Pre-2005 V6 Mustang 28 11-30-2003 02:05 PM
02:01 AM
