underdrive pulley - Mustang Evolution
Old 07-13-2009, 08:55 PM   #1
Risingsun's Avatar
underdrive pulley
I got a question about this. I know that full underdrives gives a bit of power but youll often screw up the alternator s ability to charge right and you may get dim headlights,e tc.
Can you run just one crank underdrive pulley then, and still gain some power? thnx.
http://static.mustangevolution.com/signatureuploads/sigpic10817_1.gif
94 cobra
Risingsun is offline   Reply With Quote
Old 07-13-2009, 11:32 PM   #2
Re: underdrive pulley
An underdrive pulley is just one pulley, on the crank. If you are concerned about the alternator running low at idle (this will be the only place you should see problems) get an overdrive pulley for the alternator and you'll be good to go.
Old 07-14-2009, 08:36 AM   #3
You may need an alternator pulley as fox bodies can have issues (cant remember what year they upgraded the stock output on the alternator~)
Old 07-15-2009, 01:29 PM   #4
Risingsun's Avatar
thanks for the info.
I didnt know underdrive pulleys consisted of just one pully.
94 cobra
Old 07-15-2009, 02:36 PM   #5
bbunt302's Avatar
You really should upgrade to a 130 amp alternator (also called a 3G alternator). This is what they started using in 94+. I have one and still have charging problems with my electric fan.
Scary stuff.
Old 07-15-2009, 11:13 PM   #6
Risingsun's Avatar
So your running a underdrive pulley?
94 cobra
underdrive pulley blackonblack Pre-2005 V6 Mustang 17 12-29-2009 09:46 PM
Underdrive Pulley mrjones3133 Pre-2005 V6 Mustang 11 08-10-2009 04:58 PM
Underdrive pulley obxdude018 Pre-2005 V6 Mustang 7 07-27-2009 05:07 PM
Underdrive Pulley 3Point8 Pre-2005 V6 Mustang 16 03-25-2004 07:52 AM
underdrive pulley 232SCstang Pre-2005 V6 Mustang 34 01-10-2004 07:48 AM
01:20 PM
