RPM's top out at 3,000 - Mustang Evolution
Old 04-14-2005, 06:23 AM   #1
Unhappy RPM's top out at 3,000
i have a co-worker with a 5-speed 95' GT and he says that his RPM's top out at just above 3,000 and it doesn't let him hit the red line. he just bought it a few months ago and as far as he knows the engine is completley stock. the only thing i could think of is maybe the previous owner installed a chip and set it up so that his son couldn't race it or something like that. any help guys?
2000 5spd black/ cai w/ k&n, dual exhuast w/ H-pipe
stangracer is offline   Reply With Quote
Old 04-14-2005, 08:05 AM   #2
Hm...could be alot of things. It's pretty easy to check and see if there's a chip installed though. If you want, I'll give directions. Never heard of this before though.
Old 04-14-2005, 08:52 AM   #3
i've never heard of anything like this either. he says that the car runs fine under normal driving. it idles ok and doesn't stall or anything so that's what led me to believe it might be a chip and not a problem with his heads or intake. if you could give me directions i can go ahead and check if there's a chip.
Old 04-14-2005, 09:27 AM   #4
Ok, the easiest way to check is pull off the passenger side kick panel. The ECU is located there behind some wiring. If you know what you are feeling for you should be able to feel on the top of the ECU, this is where the chip would have been put in. If there is no chip, then you will feel there is no hole in the top or anything like that. Ha..I can check in a second if I am there, but can't explain this at all.
Old 04-14-2005, 10:31 AM   #5
I liek gramer
WhiteStang99's Avatar
Jennifer's car was doing this, and it was a problem with her tranny. ****ers at a used car lot put dirt or something in her tranny so it would sound good for a while, long enough for the bastards to sell it.
Old 04-14-2005, 11:36 AM   #6
happened to my 91 300zx after "someone" pissed in my gass tank. the shop i got my car done for a/c paid me back all my money 1,800 for the a/c and replaced all fuel system components including pump and injectors. worked fine after
cjd10 is offline   Reply With Quote
Old 04-14-2005, 11:41 AM   #7
auto or manual? supposedly if your vss sensor is not connected you cant go over 40000 rpms... but if this was the case his/her speedo wouldnt work either.
Old 04-14-2005, 01:51 PM   #8
MonteCitan's Avatar
bad gas, trans problem, plugged fuel filter..
I'd start with the fuel filter personally
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-14-2005, 03:59 PM   #9
Dang... 40000 Rpm's? I dunno bout you guys but my car won't get up there....
Old 04-14-2005, 08:16 PM   #10
fast64's Avatar
i would just start with a tune up. change oil, change fuel filter and oil filter, new plugs and wires, check/adjust timing. better to spend a little money then a ton of money
GO BRAVES
Old 04-15-2005, 05:41 PM   #11
silverstangboy's Avatar
ask a ford technician, I bet they know exactly what it is..
damn I love my ford technician brandon probably does too
93 mustang notch
~450hp 331 stroker - Sold
Old 06-02-2005, 01:20 PM   #12
Rick0636's Avatar
Dealership Techs (Mechanics) are usually ok, most of them are fresh out of school for Automotive. A few stay with dealer shops for the benifits and security. Most of the really good ones go to an independant shop, or start their own shop after a few years for more money. Dealers charge the big bucks, but not that much of it actually goes to the guys doing the work.
2011 GT $43,000 edross General Mustang Discussion 16 06-09-2010 11:13 AM
rpm's for gear ratios chart Herbstang The Bar 10 06-21-2007 03:23 PM
Higher RPM's Due to Electrical Load? Rellik Pre-2005 V6 Mustang 11 03-30-2005 09:45 AM
1,000 posts :D:D:D jimmy_beaner The Bar 8 11-17-2004 06:31 AM
07:37 PM
