1995 GT cranks but no start hot - Mustang Evolution
Old 07-25-2009, 03:15 PM   #1
Hello,
I have a 1995 GT 5 speed. It cranks but doesn't start, but only after driving it for at least 3 miles and stopping. It would continue to run all day after you start it cold. If you let it cool down for an hour, it starts. I changed the cap and rotor, makes no difference. I don't have a service manual. The problem must be with something that only sends a signal when the car is starting. Like a crank or cam position sensor, and this sensor fails once it becomes warm. Just wondering if anyone else out there had this problem, and fixed it. Thanks
89beretta is offline   Reply With Quote
Old 07-25-2009, 05:02 PM   #2
Re: 1995 GT cranks but no start hot
fuel? fire? whats it not getting when it doesnt start? places id start looking at power to coil and distributor. time to whip out a wiring diagram
iamdat is offline   Reply With Quote
Old 07-25-2009, 05:03 PM   #3
fyi, your car doesnt havea crank sensor. it does however have a cam sensor/pickup in the distributor assembly
Old 07-25-2009, 09:05 PM   #4
Otlaw80's Avatar
and thats what the problem is most likely. The pickup coil inside the distributor. Its a fairly common problem. at least for me. lol Have had 3 engines do it. Starts great cold, runs fine. Turn it off and it won't start for about an hour. Then everything is fine again till you shut it off.
Old 07-25-2009, 09:34 PM   #5
Wow that's great. I knew someone would have fixed it before. I did dig up a 1994 service manual, and in the procedure for changing the camshaft sensor, it talks about using a special tool to align the sensor. But I can't tell if they are talking about the procedure for the 3.8 or the 5.0. It would be great if the part came with instructions. Thanks again.
Old 07-26-2009, 01:13 AM   #6
no thanks for me?
they're prolly talking about the 3.8 which had a camshaft synchonizer which is used for injector timing. the tool they're refering to is a circular piece with a half moon looking deal on 1 end
Old 07-26-2009, 06:27 AM   #7
Sorry man, I thought 1 "thanks button" thanked both posters. <Ahem, newbie, Ahem> Anyway you are correct, the illustration shows something like that for the 3.8, but it really doesn't talk about the cam sensor for the 5.0. So, by looking at the manual I was unclear if there even IS a cam sensor for the 5.0. And if there is, I can't tell how difficult it would be to replace it.
Old 07-26-2009, 12:39 PM   #8
the cam sensor is built in to the distributor. the cam sensor for the 3.8 is mounted on top the synchronizer assy.
to replace to cam sensor in the 5.0, you replace the distributor assembly.
Old 07-26-2009, 05:12 PM   #9
Otlaw80's Avatar
u can replace the pickup coil without replacing the distributor, and its much cheaper
Old 07-26-2009, 08:23 PM   #10
hmm, ive never seen it serviced sperately. learn something new everyday.
Hot start idle issues Scorpion1 Pre-2005 V6 Mustang 12 04-07-2009 04:58 PM
1995 GT iwannagofast 1979-1995 Mustang GT 5 01-14-2008 05:31 PM
Travis Barker Cranks This n8r Pictures and Videos 9 10-16-2007 09:32 PM
Will not start when hot SJLOGAN 1979-1995 Mustang GT 7 06-03-2007 09:02 AM
1995 GT a00v6stang 1979-1995 Mustang GT 9 01-29-2006 01:03 AM
06:19 PM
