Quick question! - Mustang Evolution
Old 05-02-2005, 12:24 PM   #1
Scut95's Avatar
Quick question!
hey....i was thinking about stroking my 5.0 to a 347. The only problem is, they just started doing emissions testing in my area. How difficult and expensive is it to build a stroker and keep it emissions legal? And does anyone know a good kit out there?
Old 05-02-2005, 03:09 PM   #2
A stroker kit shouldn't change your emissions as long as you still have your cats on...
Old 05-02-2005, 03:16 PM   #3
bluemustang's Avatar
^ what he said as long as you have cats your in the clear, plus theres always hi-flo cats its the next best thing plus I barely passed my states emission with them on too.
As for who makes good kits id have to say Keith Kraft and DSS are two of the best companies in my opinion that make good kits/blocks
Old 05-02-2005, 03:43 PM   #4
Keep cats on your car you should be fine.
Old 05-02-2005, 06:31 PM   #5
Tbird232ci's Avatar
and a good tune
Old 02-15-2006, 10:24 AM   #6
FakeSaleen's Avatar
Re: Quick question!
just build a 351w more power less money and still room to grow
FakeSaleen is offline   Reply With Quote
Old 02-15-2006, 01:07 PM   #7
Bane-'s Avatar
Re: Quick question!
the only thing you could run into for emissions really are your H/C/I because stock will not do diddly for a stroker, keep your egr and all that fun stuff, and get a cam that isnt really radical and still emissions friendly and you will be fine. stock H/C/I on a 347 would be a complete waste of money on the rotating assembly.
Old 02-20-2006, 03:14 PM   #8
FakeSaleen's Avatar
Re: Quick question!
if your really worried about it run the gas out of it and run ethenal for the emisions test. leave a little gas in it because if you run 0.0 emissions they will suspect something. only run what you need to do the emissions test cause the ethenal can funk up the cats and the o/2 sensors
Old 02-20-2006, 07:59 PM   #9
MonteCitan's Avatar
Re: Quick question!
my 331 just passed emissions.. I swapped back to a stock catted H and bumped timing down to 6 degrees advance.. aside from that I didn't change a thing.. passed with flying colors.. I have everything from larger injectors to flow tested heads.. if I had a high flow DOT legal H or X pipe and stock timing I coulda passed too, at this rate.. but since I run an offroad and 14*.. it woulda been close or over.. lol
yeah.. you should have no problems if you have cats
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
quick question durtyred69 1979-1995 Mustang GT 5 01-13-2011 11:15 AM
quick question jonbean Pre-2005 V6 Mustang 1 07-16-2009 02:48 PM
i got a quick question yoast88 1996-2004 Mustang GT 3 01-16-2009 03:26 AM
quick question ttpancakes The Bar 8 12-11-2004 08:21 PM
quick question Thomas91169 The Bar 9 03-19-2004 12:53 AM
05:28 PM
