Installing MSD ignition - Mustang Evolution
Old 05-12-2005, 10:39 AM   #1
Zim
You want to **** me?
Zim's Avatar
Alright, my car has an MSD 6A box in it, but its not hooked up... so I want to hook it up but cant figure out a couple things. First, on the coil of the car where the heck is the positive and negative wire for it? Would they be the wires that are attached to the little dilio that plugs into the coil? Also, wheres the easiest place to splice into a wire that is only activated when the key is turned? and last, what would this be "From Points or Electric Ignition Amplifier (original coil (-) wire)"???
any help would be sweet
I like toys
Old 05-12-2005, 10:41 AM   #2
I would HIGHLY recommend seeing if you can download online instructions or get em mailed to you find em some way.
Old 05-12-2005, 10:50 AM   #3
Zim
Zim's Avatar
I found some, but theyre just not really clear. THey tell me where all the wires are supposed to go, I just dont know where those wires all are on my car lol
I like toys
Old 05-12-2005, 10:50 AM   #4
SrATEX's Avatar
damn....kinda glad i dont have the 6A box yet. when i did my ignition upgrade is just got the MSD TFI Blaster coil, Ford Racing 9mm wires, Ford Racing Cap and rotor(same price as regular but have a cool name), and motorcraft plugs.
Coil had a harness that just snapped into it, pulled it off the factory coil and plugged it into the MSD one, then had the wire that ran from the coil to the cap. gapped my plugs at .50 instead of .44. noticed a nice little increase in MPG
Supermotors
Old 05-12-2005, 11:02 AM   #5
Zim
Zim's Avatar
Yeah im wondering if theres a couple harness' that I dont have and need, cause all the ends of the wires have nice little prongs on the end of them, but nowhere to be stuck into. It just sucks knowing thats there and not being able to use it lol
I like toys
Old 05-12-2005, 11:05 AM   #6
SrATEX's Avatar
here is mine
Supermotors
Old 05-12-2005, 12:18 PM   #7
To be honest You are probably better off not using it. You really dont need it unless you have a heavily modded engine. The stock ignition should do fine. If anything just replace the coil and go with that.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 05-12-2005, 12:25 PM   #8
Zim
Zim's Avatar
my car does have a pretty good amount of mods, and im going with nitrous soon too, so I think i would benefit from it
I like toys
Old 05-12-2005, 12:32 PM   #9
Ill see what I can find fer ya in the way of install docs. then.
96 GT 4.6 L
B&M Shifter
Bassini O/R X Pipe
C&L MAF
WMS CAI
Old 05-12-2005, 12:42 PM   #10
The PDFs on this page should show you everything you need to hook it up. I looked them over and seems fairly straight forward.
http://www.msdignition.com/downld1.htm
96 GT 4.6 L
B&M Shifter
Bassini O/R X Pipe
C&L MAF
WMS CAI
Old 05-12-2005, 01:14 PM   #11
fast64's Avatar
lemme know how the harness works out for ya zim
GO BRAVES
Old 06-05-2005, 02:27 AM   #12
Yellow5.0's Avatar
i belive u can get a tfi harness that will make it super easy to hook the ignition up on that car i would highly recommend just getting that
http://www.mustangevolution.com/gallery/data/502/1.jpg1995 GT- GT40 iron heads, 1.72 cobra roller rockers, FMS shorty headers, flows welded in, bbk o/r h, bbk UDP, steeda tri ax, timing advanced to 13, CAI, 75mm granatelli MAF, Eddy performer intake, 17x9 chrome cobra r's, mach 1 chin spoiler
for pics of my car go here-->car pics
Yellow5.0 is offline   Reply With Quote
Old 06-05-2005, 05:36 AM   #13
fast64's Avatar
thats what i told him to do, he ordered one and has had an msd ignition for like 3 weeks now
GO BRAVES
Old 06-11-2005, 11:35 AM   #14
silverstangboy's Avatar
yeah, the nitrous will be the only reason you'd want to upgrade. your car doesn't need all that, I mean my buddy that had a hatch with TFS TW heads and 18 lbs of boost from a *-Trim put the top of the line MSD box on (the one that does multiple sparks per revolution) and it netted nothing, no serious change in horsepower, or quarter time. however I think he did say it helped some in the gas mileage department. my point is that it takes a heavily modded car for that to be an improvement, and heads cam and intake alone is only light to medium modded especially when the heads are mediocre like the home ported gt-40 irons. (don't think im knocking them though, mine kick ***)
regardless, if I were in your possition and it was just there in the engine bay already, i'd be hooking it up too good luck
93 mustang notch
~450hp 331 stroker - Sold
Old 09-17-2005, 11:51 AM   #15
Re: Installing MSD ignition
msd hooks up to a duraspark distributor using the 2 colored wires and not using black wire on distributor.
second setup could use the white wire connected to points. basically you send a pulse from your distributor module or points to the msd and ZAPPPP!
The msd sight will tell all info in pdf format.
2 heavy red and black go to battery, small red to switched ignition.
kurt herold is offline   Reply With Quote
?? with msd before i even try casper911v8 1979-1995 Mustang GT 0 09-03-2009 03:12 PM
MSD ignition help blown347ranger 1979-1995 Mustang GT 12 05-30-2007 04:09 PM
msd ignition ****** theglory 1979-1995 Mustang GT 11 09-19-2005 08:47 AM
Msd Ignition ****** Controller theglory 1979-1995 Mustang GT 4 02-24-2005 10:50 PM
04:47 AM
