Distributorless ignition (DIS) - Mustang Evolution
Old 08-14-2009, 08:18 PM   #1
Otlaw80's Avatar
I've been thinking about converting my 5.0 to a distributor ignition system. Mostly to get rid of the distributor but also I think there might be better(stronger) spark as well as a few bucks saved from replacing caps and rotors. I was originally thinking of taking the system off of an explorer with a 5.0. I know i would need the coil packs, cam sensor, the timing ring on the crank. But I'm also thinking the explorers with this system are all OBDII and mine is not. What are the differences as far as sensors go? Could I pull the computer of an explorer also or would i need to have a custom tune done? I've been doing some searching but haven't found anything that really lays it out for me.
Am i crazy?
Old 08-14-2009, 09:00 PM   #2
Re: Distributorless ignition (DIS)
honestly, totally not worth it. if your mind is set on this, i can be of more assistance but i suggest just upgrading what you got (good coil, cap, etc..) and add an ignition box
iamdat is offline   Reply With Quote
Old 08-14-2009, 09:59 PM   #3
Otlaw80's Avatar
I"m not totally set on it. Would like to hear your take on it and anything else you may know about doing it. If for no other reason just to know. Also what exactly does an ignition box do/help with over a stock setup?
Old 08-15-2009, 06:57 AM   #4
mchaggis50's Avatar
*also interested*
'94 GT aode. Cobra intake, AFRs, 1.7s, Mac/flowmaster exhaust, Hughes 2500 stall, 3.73s, Eibach, bilstein, blah blah. Smelly, fun and loud!
mchaggis50 is offline   Reply With Quote
Old 08-17-2009, 02:05 AM   #5
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Originally Posted by mchaggis50 View Post
*also interested*
same... don't really know a lot about that...
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 10-09-2009, 07:35 PM   #6
I believe you would need the ecu to run those coil packs along with cam senser and you would need to run the knock sensers out of the exployer not a 100 persent though just thinking out loud.
chris r is offline   Reply With Quote
MSD ignition help blown347ranger 1979-1995 Mustang GT 12 05-30-2007 04:09 PM
McCain: I'm in dis bish Brent The Bar 23 04-26-2007 01:00 PM
Need help with some possible Ignition upgrades Kiljosh Pre-2005 V6 Mustang 10 11-30-2005 11:26 PM
MSD Dis-4 4/sale BKB Mustang Parts for Sale and Wanted 0 02-10-2004 08:09 PM
Better ignition for 98.... TheSarge Pre-2005 V6 Mustang 2 09-15-2003 09:43 PM
12:21 AM
