Changing my T-stat... lil help - Mustang Evolution
Old 05-25-2005, 03:43 PM   #1
Zim
You want to **** me?
Zim's Avatar
Im gonna put a 180* T-stat in my car (or 160* if thatd be better) to see if it helps my cooling situation at all. I know where the things at, but I need to know where I flush the radiator fluid from. Anyone that can help me out on where the drain plug is for the radiator, and give me any helpful tips about changing the T-stat... Id appreciate it.
I like toys
Old 05-25-2005, 03:44 PM   #2
its a white looking bolt on the side of the radiator on the passenger side of the engine bay side. Its at the bottom of the raidator, just pull it and the coolant will come out. Remove the radiator cap to help it drain and when its done also remove your overflow bottle and clean that sucker... there is some NASTY stuff in there that needs to be removed, hot water and a little shaking will remove it.
Old 05-25-2005, 03:50 PM   #3
Zim
Zim's Avatar
cool thanks
you think a 180* t-stat would be sufficient or should I go to a 160*?
I like toys
Old 05-25-2005, 03:51 PM   #4
180 is what I would run a 160 will be to cold IMO
Old 05-25-2005, 04:00 PM   #5
fast64's Avatar
i run a 160* t-stat, but i plan on driving a supercharged car in 100+ * weather, a 180* t-stat should be good enough for you.
GO BRAVES
Old 05-25-2005, 05:19 PM   #6
its not a big deal to put in a new one if you get heads/cam/intakes/blower/etc so just sticka 180 in it for now.
Old 05-25-2005, 05:46 PM   #7
Zim
Zim's Avatar
i have heads, cam, intake... and soon nitrous
I like toys
Old 05-25-2005, 05:47 PM   #8
which heads/cam/intakes are you getting
Old 05-25-2005, 05:52 PM   #9
Zim
Zim's Avatar
ive got the cobra intake, ported gt40 heads, and an e303 cam... it sounds completely unrestricted
I like toys
Old 05-25-2005, 06:00 PM   #10
ah, i thought you ment you were getting different ones, your not flowing so much that you should really worry with a 160 t-stat the 180 will be perfect for you. My friends 5.0 has AFR 165's with a custom ground cam (not sure on specs) and Edle performer upper/lower so he has more flow, and he still doesnt need any lower than a 180. If you was to put a blower on it you might... you would probably still run with a nearly perfect temp.
Old 05-25-2005, 09:13 PM   #11
silverstangboy's Avatar
yeah, I wouldn't go that low, i've heard a few people complain about driveability changing when going that cold on iron headed 302's specially that new computer you have
93 mustang notch
~450hp 331 stroker - Sold
Old 05-25-2005, 10:21 PM   #12
Tbird232ci's Avatar
yes, the computer doesnt like closed loop with that low of a thermostat
Old 06-01-2005, 09:26 PM   #13
Rick0636's Avatar
If you are having cooling problems, the radiator could need to be professionally boiled out and checked for leaks, the thermostat that is in there could be sticking, or, with the added hp you are running its possible you may need a larger aftermarket maybe, radiator to cool it more. 180* thermostat is ok, 160 CAN cause problems with you computer as already stated, it can also cause other problems which might be associated with the engine running well below manufacturers specs. for temp.
lil photoshop help please. Bane- The Bar 5 03-12-2009 08:50 PM
Need a lil help here iwannagofast Pre-2005 V6 Mustang 3 10-30-2007 10:12 AM
lil to loud... Bane- Pictures and Videos 4 04-14-2005 09:00 AM
lil help midnightmustang Mustang Wheels & Tires 3 03-20-2005 10:19 AM
just a lil somethin... Zim The Bar 35 01-21-2004 08:05 PM
03:40 AM
