94 302ci swap to 351ci??? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 09-04-2009, 11:44 AM   #1
matts94gt is unknown around these parts
I have a 94 gt mustang, I may change my plans a bit and go with a 351ci instead of building my 302. my major qeustion here is will the 351 block bolt in the same as the 302? tranny? how aout the top end? can a 302 top end kit say a trickflow track heat with twisted wedge heads bolt on? also what about the factory A/C and alternator/ cerpintine system is it all the same? if so with the top end kit on a factory 351 short block how many hp would you expect it to produce?
thanks
Matt
matts94gt is offline
Old 09-04-2009, 06:10 PM   #2
Otlaw80's Avatar
Otlaw80 is unknown around these parts
Re: 94 302ci swap to 351ci???
Engine will bolt in exactly the same, use exactly the same trans. Difference is the deck height. You will need a few things. Here is a link for you. Its actually for fox bodies, but it will be almost identical for your 94. This is my plan for my 95 as well. But it may change since i can never make up my mind. 351 Engine Swap - 5.0 Mustang & Super Fords Magazine
Otlaw80 is offline
Old 09-04-2009, 08:11 PM   #3
Thanks Bro!!!!
I know what you mean about changing your mind too LOL....
Matt
Old 09-04-2009, 08:58 PM   #4
bbunt302's Avatar
bbunt302 is unknown around these parts
As long as you are talking a 351 Windsor, all the top-end engine pieces will work okay. You could stand to go with a little wilder combo with the extra displacement, but with something like the Trick Flow kit, you will make tons of torque. It should be a fun ride.
The only problem is finding a factory 351 Windsor that is set up for a hydraulic roller cam. I believe the early Lightnings and the '95 Cobra R were the only factory 351 Windsors with roller cams.
Scary stuff.
bbunt302 is offline
Old 09-04-2009, 09:03 PM   #5
how about this short block?
79-95 Short Block, 5.8L Economy, Accepts Roller Cam at LRS - Same Day Shipping!
Old 09-04-2009, 09:10 PM   #6
Otlaw80's Avatar
I believe the bronco's and some of the vans that had 5.8's in them in the late 80's early 90's had roller cam 351's. you can also use stock 5.0 roller lifters with a retrofit cam made by a few cam companies.
Otlaw80 is offline
Old 09-04-2009, 09:11 PM   #7
Otlaw80's Avatar
And if your talking about spending 1k on a short block, and2500 on top end kit, plus you'll have to buy the other necesities , you might be better off looking for a crate engine? Just a thought. How much you looking to spend on the motor?
Otlaw80 is offline
Old 09-04-2009, 09:35 PM   #8
cost wise I was hoping to stay in the $4500 area or less. but that may not e possible...
what crate would you recomend? I want to keep EFI and A/C, and powersteering...
Matt
Old 09-05-2009, 09:30 AM   #9
bbunt302's Avatar
I would recommend not going the crate engine route. They tend to be overpriced for the power they make.
As for the short block you posted earlier, it may be ok as long as you are not going to be using any type of forced induction. I would almost be scared to buy an "economy" short block though.
Scary stuff.
bbunt302 is offline
Closed Thread
WHAT DO I NEED FOR A 5.0 swap Zebs5408 Pre-2005 V6 Mustang 6 10-23-2009 05:27 AM
94 302ci build configuration help. matts94gt 1979-1995 Mustang GT 7 09-05-2009 09:28 AM
V6 to V8 swap... metalfuse Pre-2005 V6 Mustang 2 01-15-2009 10:11 AM
11:55 PM
