Removing crank pulley on 87 lx 5.0 5 speed - Mustang Evolution
Old 07-01-2005, 12:22 PM   #1
I liek gramer
WhiteStang99's Avatar
Friend of mine says he's having a hard time removing his crank pulley on his 87 5.0.
I can't see what his problem is, since he's in Montgomery and I'm stuck up here in Decatur, but any tricks to help him get it off?
he says "i bought a harmonic balancer remover for that..but i have just a 15/16 socket for the crank"
Old 07-01-2005, 12:24 PM   #2
you back the middle bolt out a bit, then you use the pulley puller to pop her out, you got to pull the middle bolt out in order to have a place for the pulley to go.. the bolt is currentyl holding it from moving at all. That bolt is a PITA lol
Old 07-01-2005, 12:25 PM   #3
you may have to take the pulley off also
Old 07-01-2005, 01:03 PM   #4
fast64's Avatar
the pulley on my motor is just held on with 4 hex bolts, i didn't even need a puller to get it off, maybe he needs to take the pulley off like that first, then pull the balancer off?
GO BRAVES
Old 07-01-2005, 01:10 PM   #5
I liek gramer
I dunno, I can't see it, and I've never really been around many 5.0s.
Old 07-01-2005, 02:05 PM   #6
bbunt302's Avatar
He's going to need an impact, if he isn't already using one. If you try to break them loose with a wrench, you just turn the motor over. Other than that, I don't know what his problem could be.
Scary stuff.
Old 07-01-2005, 05:48 PM   #7
if its an auto you can get her off, or if its in gear and the rear wheels are on the ground or ebrake is up... but impact makes life much much easier.
Old 07-01-2005, 06:32 PM   #8
I liek gramer
Title says 5 speed...
He got it taken care of, thanks guys.
Old 07-01-2005, 09:23 PM   #9
MonteCitan's Avatar
I put the car in first, locked the E Brake, soaked it with PB blaster, let it sit overnight.. then went out again with a large breaker bar..
If possible though.. Get an impact gun on it.. less chance of breaking it
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-30-2005, 07:59 PM   #10
Rick0636's Avatar
Re: Removing crank pulley on 87 lx 5.0 5 speed
I gotta get a box and wire my shed for about 25 or 30 amps so I can run my compressor without blowing breakers all the time, yes, impact is great! All air tools are great for that matter.
cant get crank pulley off Thomas91169 1996-2004 Mustang GT 23 03-23-2006 09:25 PM
94-98 Underdrive Crank Pulley dapack69 Mustang Parts for Sale and Wanted 0 09-29-2005 10:09 PM
removing crank pulley... MonteCitan 1979-1995 Mustang GT 15 03-01-2005 10:48 PM
differences betwen 4.2 and 3.8 crank Pulley? Horse Pre-2005 V6 Mustang 3 07-14-2004 09:24 AM
Crank Pulley and New Harmonic Dampner Stang01 Pre-2005 V6 Mustang 1 07-17-2003 06:36 PM
08:53 PM
