Interesting problem.... - Mustang Evolution
Old 07-11-2005, 11:10 AM   #1
well first off let me tell you bout the ride. i have an 88 gt conv. it has bbk intake, h pipe with flows and thats all rite now. i just got it not too long ago but the mods are already startin. but first i have to fix some things to make it a lil more reliable. now onto the probs...
first of all, if the car has been sitting over nite it starts fine even in pretty cold, which it doesnt get that cold considering im in cali. but then if i drive it enough to get the engine warm (like 45-hour) and park it for like 30 min or more it wont start until it cools completely off like 2 or more hours. if i try to start it less than 30 min parked it starts sometimes even if its hot. so this confuses me cuz i dont kno if its an ign prob or a fuel prob. on to the next prob...
in first gear when i first start driving if i press the gas too much the car stalls for a few secs then starts and runs again on its own. it also does this everytime i make a rite turn basically no matter what. usually it stops doin it in first gear if the engines warm and every once in awhile on rights. but the wierd thing is it starts itself back up and runs. now i dont know if this is pre-detonation of what. im just gettin into mustangs again and know some stuff but now a ton.
any help on either of these probs would be much appreciated. thanks
chris
stangedout916 is offline   Reply With Quote
Old 07-11-2005, 11:54 AM   #2
Danger Dude's Avatar
Ok let me get this straight. Are you saying once it is hot it will turn over but not start
Old 07-11-2005, 01:01 PM   #3
the starting problem sounds like a starter issue.
I know that if they're on their way out, they will work when cold but once they get hot they stop working and you have to let them cool down.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 07-11-2005, 01:15 PM   #4
He has not said if it was turning over or not. if it does not turn over it is definately either the Starter or wiring in between it and the battery. If it does turn over it is probably a fuel issue. I had a Mazda truck that would start fine it would get hot and turn over and not start. Found the fuel line was getting hot cause vapor lock
Old 07-11-2005, 01:43 PM   #5
Tbird232ci's Avatar
sounds like a possible fuel issue to me, check you fuel pressure when its hot, and see if the pressure is dropping off as your pump is getting hot, mine did the same thing
Old 07-11-2005, 03:02 PM   #6
Bane-'s Avatar
my starter did the same thing to me though to lol, drove an hour came, parked came back to the car a hour later and gave me a fit trying to start...got it home and was messing with getting everything out and the motor kept trying to start on it own, (keys werent even in or nothing) would just crank and the belt would spin maybe a inch or 2 then it would stop and do it again...did this a few times, new starter is in and no starting problems also for the studdering problem whens the last time you did a tuneup?
Old 07-12-2005, 08:31 AM   #7
yea danger it sounds like wat was goin on with your truck. when it gets hot its cranks but wont turn. its not the starter im almost positive. iv had some people tell me its the ignition, and others say its the tpi or tfi sensor? but i thought it might be a fuel issue also. so wat did you have to do for your fuel prob? i was gonna get a full aeromotive fuel system at some point but dont have that kind of money right now so whats a budget way to do this? thanks for all the input.
chris
Old 09-17-2005, 12:00 PM   #8
Re: Interesting problem....
is timing off or advance sticking?
headers near starter?
broken wire in distributor that makes and breaks contact during vacuum advance rotation internally to distributor? this was a common gm problem in early hei systems
under high vacuum full throttle- the distributor plate rotates internally and a wire is stressed and breaks until rpms or vacuum drop and wire makes contact again
kurt herold is offline   Reply With Quote
Interesting problem? braumab 2005-2010 Mustang GT 13 01-09-2009 03:00 PM
Interesting computer problem PureVenom The Bar 10 01-25-2006 05:13 PM
Interesting, very interesting.....hmmm Rick0636 The Bar 6 05-04-2004 11:06 AM
Interesting problem ASSEMbler Pre-2005 V6 Mustang 2 03-05-2004 05:55 PM
» Members Mustangs
Mustang
sbeard73
Todd
tjzola
Add your Mustang
11:17 AM
