Hesitation in Accelerating... - Mustang Evolution
Old 07-19-2005, 01:11 PM   #1
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Hey guys! Well I have a little problem, nothing big, say im leaving a stop light, push on the gas and I start accelerating, and then while im accelerating, it hesitates for a second or two, and then keep on accelerating, while im on the gas the same amount the entire time, I am probably thinking, Fuel Filter, Fuel Pump, something to do with fuel maybe, what are your opinions?
Edit: Oh ya and this is just NORMALLY accelerating, not getting on it at all.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 07-19-2005, 07:10 PM   #2
Is it missing any? Or just hesitating? I'd check the fuel filter first.
Old 07-19-2005, 11:14 PM   #3
Its just hesitating... If I we're to let off and punch it, it takes off like a bat out of hell.
Old 07-19-2005, 11:20 PM   #4
Tbird232ci's Avatar
how much gas is in the tank when you do this?
my car, ill get on it, and itll pull, hesitate, pull, hesistate, all the way up through the RPMs when i dont have much gas in the car, because the gas is sloshing around
Old 07-20-2005, 09:14 AM   #5
MonteCitan's Avatar
automatic or manual?
if its a manual it might be an EGR problem
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-20-2005, 09:30 AM   #6
hmm, umm, well considering my gas gauge dosnt work, I know I dont have much in there right now, ill get a full tank and see if it happens, but the thing is it only happens for a second or two, if I get on it, it might hesitate for a brief second but then it just launches, dosnt hesitate at all, and I have an auto.
Thanks!
Old 07-20-2005, 01:33 PM   #7
try changing the fuel filter and all that, good idea to anyway.
Old 07-20-2005, 04:22 PM   #8
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
the answer is simple, drive it at wot every where you go....jk but it could also be your TC, but i hope not for your sake
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 07-20-2005, 05:22 PM   #9
TC?
Old 07-20-2005, 05:42 PM   #10
torque converter.
Old 07-20-2005, 06:42 PM   #11
Danger Dude's Avatar
You could have a TPS going out or intermittently working right at the ,moment of movement but when you hit the throttle hard it skips that area and goes wide open and works normal. I would also look at the possibility of a dirty MAF
Old 07-20-2005, 07:12 PM   #12
fast64's Avatar
if you check the TPS, make sure it is not tightened down too much, it can keep your throttle blade from opening and closing smoothly.
GO BRAVES
Old 07-21-2005, 03:53 PM   #13
MonteCitan's Avatar
speaking of MAF.. if you have an oil media filter (K&N or something like it..) you might have a fouled MAF.. get some electric contact cleaner (make sure it specifies no residue) from a parts store and spray the wires on the MAF
Old 09-17-2005, 11:55 AM   #14
Re: Hesitation in Accelerating...
doubt fuel filter is problem- it would be worse at WOT due to flow restrictions.
kurt herold is offline   Reply With Quote
Old 11-27-2005, 01:14 PM   #15
Very likely could be your oxygen sensors. mine were making my 88 run a little rich and hesitate, but she would still get on it. also the air bypass on your throttlebody can get dirty and make it idle crappy when it's cold.
bluebullett is offline   Reply With Quote
Old 11-28-2005, 06:09 AM   #16
umm where exactly is the air bypass on the throttlebody? it does idle a little rough, but I found out it was just not enough gas in my tank, because I can turn right onto a road and kind of push it and it hesitates and goes, I filled up and did it again and I just punched it and it ran straight threw with no problems.
Hesitation classman Pre-2005 V6 Mustang 2 06-16-2010 09:12 PM
Hesitation acceleration blue95stang General Mustang Discussion 7 07-30-2008 10:26 AM
e-brake light turns on while accelerating 1997grnstang Pre-2005 V6 Mustang 6 10-22-2006 12:31 PM
Hesitation at 40-50 MPH mustang2002 Pre-2005 V6 Mustang 8 05-03-2006 07:51 AM
'02 GT Hesitation?? SHAG5150 1996-2004 Mustang GT 4 03-16-2006 02:09 AM
11:29 AM
