engine swappp - Mustang Evolution
Old 10-14-2009, 08:13 PM   #1
1980rustang's Avatar
engine swappp
i have a 1980 mustang. it has the inline 6 k member but im going to swap in a 351w. will i need to change the k member? will a c4 bolt up to the 351w and i read that the aftermarket k members move the front wheels forward 3/4 to 2 inches is this true
1980rustang is offline   Reply With Quote
Old 10-14-2009, 08:58 PM   #2
OsirisGuy's Avatar
Re: engine swappp
I do believe you will need a new K-member. If you go with an auto transmission I do not know about the C4 but you can probably get a T-5 manual transmission to fit in nicely. The movement of the K member may depend on what K member you go with. Chances are if you go aftermarket you can probably find a near direct replacement. Getting a K member from another model year, different model altogether, or aftermarket for different applications you will probably have to do some custom fabrication work to avoid moving the entire suspension.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-14-2009, 09:04 PM   #3
Re: engine swappp
i live in ny so if there is a chance that thre will be a stock k member on a mustang in my year it will be rusted to hell here so i think i might have to go after market and im still debating on the trans i would love to go to a standard but money is super tight cause i have to store my camaro and get a truck for winter
Old 10-14-2009, 09:15 PM   #4
OsirisGuy's Avatar
Re: engine swappp
Rebuilt T-5s are pretty cheap, like $500 bucks. A guy here on LI buys them, rebuilds them and sells them.
You can still try going second hand maybe get lucky. I think there are quite a few "four eyed foxes" on ::LIStangs:: and since you are more upstate you may have some better luck with New York Mustangs - NY Mustang Club, forum cruises, shows, meets, races, events, message boards, and more. in finding some spare parts for the car.
OsirisGuy is right
2002 Mustang GT
Old 10-15-2009, 06:54 PM   #5
Re: engine swappp
yea i dont even have that i make about $70 a week thanks to the dam economy and all my money goes into a truck fund cause the mustang dont have a engine and the camaro has 2 bald front tires
Old 10-20-2009, 07:19 PM   #6
Re: engine swappp
so i just bought a hand built k member that will work with the stock a arms but it says it only uses coil overs are those just a bolt in instead the stock shocks and taking out the springs or is there more to it?
Old 10-20-2009, 09:02 PM   #7
Re: engine swappp
Please pm me that guys info. I need a trans for my 93 4 cyl to 8 cyl swap.
Old 10-20-2009, 09:09 PM   #8
Re: engine swappp
back to my questions so i just bought a hand built k member that will work with the stock a arms but it says it only uses coil overs are those just a bolt in instead the stock shocks and taking out the springs or is there more to it?
Old 10-20-2009, 09:15 PM   #9
Re: engine swappp
Coil overs are springs over the shocks the stock springs come out and you use coil over style springs. Upr has a complete k member kit with control arms and coil overs for 700 total. Otherwise, you could get the qa1 and get the stock spring perches that let you use your stock springs with your stock a arms. Youmay be able to just buy the qa1 spring perches since you already have the kmember.
Old 10-20-2009, 09:18 PM   #10
Re: engine swappp
i bought one off ebay that doesnt have the spring perches so i have to use coil over im just looking for some not too expensive ones cause im on a super tight budget ive gotten everything on this car as a gift or free
Old 10-20-2009, 09:23 PM   #11
Re: engine swappp
Spring perches are seperate pieces that bolt up to whee the kmember meets the frame. They are not brand specific.
As for coil overs, there is no such thing as a cheap coil over setup unless you can get them used off a wrecked car or from a buddy.
Old 10-20-2009, 09:25 PM   #12
Re: engine swappp
not what i wanted to hear but ok as for the motor mounts do i need ones that bolt to an aftermarket k member or are they like any other motor mount that is available
Old 10-20-2009, 09:30 PM   #13
Re: engine swappp
It uses stock motor mounts. If tour stockers are still good, those are fine. If you need new ones, you just need stock replacements.
Perches will only run you about $60 I believe and you can just reuse your stuck suspension parts.
Old 10-21-2009, 05:30 PM   #14
Re: engine swappp
i have inline 6 mount so ill have to get new ones any cheap mounts?
Old 10-21-2009, 05:59 PM   #15
Re: engine swappp
150ish for the set no matter where you get them. That's aftermarket. OEM may be cheaper.
Old 10-21-2009, 06:32 PM   #16
Re: engine swappp
what! everythings so dam expensive! im not made of money (not even close)
POSSIBLE NEW ENGINE upton7 1996-2004 Mustang GT 19 06-13-2009 04:06 AM
V6 Engine Help kack85 Pre-2005 V6 Mustang 3 01-08-2009 09:37 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
10:25 AM
