Rocker geometry - Mustang Evolution
Old 09-17-2005, 11:30 AM   #1
Rocker geometry
Hello- i have a 92 block 347 stroker 66 mustang coupe with a t5 and a 3:50 locker rear.
My engine seems to have noisy valvetrain and breaks up at high rpms - even though it is balanced and tuned.
i have just added a msd 6a ignition and a rebuilt duraspark distributor to solve the problem. during the process i thought i would check valve springs to see if i had a broken one. I have a summit 285 duration 540 lift cam and trick flow valve spring kit- with correct installed heights.
I discovered the rocker bottom radius is rubbing the radius on the bottom of my comp cams screw in studs by about .040 and has started to gouge stud there because the rocker is too low.
I assume i had some valve sticking due to this and was going to install longer pushrods to compensate. PROBLEM ..... a longer pushrod would cause my roller tip on my 1.6 comp cams magnum rockers to be well below the centerline of my valve using the marker metheod of checking. They are already a tad lower than i would like.
I am considering adding .080 valve lash tips to my setup. - this would presumably raise the rocker enough to clear the rubbing ( barely ) and should bring the rocker roller closer to the center of the valve.
Is this a legit fix???? i cant afford longer valves and all that work.
Thanks for your great sight here..... Kurt
kurt herold is offline   Reply With Quote
Which female rocker do you think is the hottest? sonic04edge The Bar 21 08-04-2008 04:27 PM
springs and rocker arms tigerfan2771 Pre-2005 V6 Mustang 2 05-25-2008 08:27 PM
rocker arm help rbhasychak 1979-1995 Mustang GT 4 08-14-2007 05:04 PM
Rocker Geometry Tech RGR Pre-2005 V6 Mustang 3 03-22-2005 09:52 AM
Will a roller rocker from a 5.0 (1.72:1) fit an 00 3.8l? tire Pre-2005 V6 Mustang 15 11-26-2003 02:56 PM
05:12 PM
