Is traction really improved ? - Mustang Evolution
Old 10-01-2005, 06:47 PM   #1
Joel5.0's Avatar
Finally got all the parts to do a gear change from a 2.73 to 3.90 and overhaul the limited slip. I am looking now at improving traction and checking the different lower control arm alternatives (Lakewood, JEG's, Summit, FRPP, Steeda, etc).....if you have one installed, could you share the experience ?
Do they work ?....are they worth the bucks ?.... which type is better, adjustable or non-adjustable ?
Thanks
Joel5.0 is offline   Reply With Quote
Old 10-01-2005, 08:37 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Is traction really improved ?
bigger tires.
Old 10-02-2005, 01:01 PM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
www.maximummotorsport.com for all your suspension needs
they > all
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 10-02-2005, 02:34 PM   #4
Monkey's Avatar
I had a set of Ground Pounder upper and lower control arms. The LCAs helped keep my tires planted when I was at the track doing burnouts and eliminated wheel-hop. Non-adjustable ones will be fine unless you are going for a certain weight distribution in your front to rear loading, etc.
Old 10-02-2005, 08:15 PM   #5
Danger Dude's Avatar
they > all
BULL!!!!! They are good but they have equals. You have been brain washed by hype. Can I interest you in a Electric supercharger for $60
MUHAHAHAHAHHHAHAHAHHAA
Old 10-02-2005, 08:16 PM   #6
I have one mm component in my suspension...and that's my 4 way adjustable c/c plates. There are places that have just the same equal stuff, if not better...
Old 10-02-2005, 10:54 PM   #7
Tbird232ci's Avatar
Kenny Brown, Griggs, or Maximum Motorsports
they are the top 3, dont buy any BBK junk
Old 10-03-2005, 12:16 AM   #8
maximum motorsports for lowers, or any sperical bushing lower control arm.... but only one company makes them that I know off... hmmmm..... or you can go with some others that have urathane bushings that give you inconsistent handling
Old 10-03-2005, 07:26 AM   #9
dark's Avatar
so that means you can edit my post?
Old 10-03-2005, 11:25 AM   #10
when it comes to lower control arms... who mm's equal? Ive yet to see one thats even remotly close unless you are brainwashed to belive urathane bushings are fine.....
I belive pro-3i makes some with sperical bushings, but they got the design from mm when they split from them...
mm is not always better, they just have amazing quality, a very very good reputation, and .... make better parts than nearly anyone for most every item.
Just ask about a particular item and we can go from there, dont buy some "steeda" or what ever lowers cuz .... they suck compared to mm (on lowers)
Old 10-04-2005, 04:55 PM   #11
Joel5.0's Avatar
Thanks for the information, looks like I'll have to take it to the max.......
Based on the long term plans, I need to go with the adjustable LCA's ($$$) .
:thanks:
31 Spline Traction 67mustang97 1996-2004 Mustang GT 1 10-03-2009 03:42 PM
Traction at the track help? ME Moderator Pre-2005 V6 Mustang 9 01-27-2008 08:01 PM
The *New and Improved* Stupid Customer Daily Update DarkShadow The Bar 100 09-15-2007 08:17 PM
traction locs all8280bcc 1996-2004 Mustang GT 1 12-20-2006 10:34 AM
New and Improved CAI Article!! Rellik Pre-2005 V6 Mustang 8 02-12-2004 12:03 PM
07:47 PM
