Rebuilt AOD stalls engine in reverse and only has 1st gear - Mustang Evolution
Old 11-11-2009, 04:33 PM   #1
91StangGT5.0's Avatar
I recently bought a rebuilt transmission that was beefed up with some Alto Red Eagle, and etc parts from a friend of mine who decided to sell it to go with a TKO. I got it installed into mine and when you shift into reverse it stalls and when you put it into drive it doesn't shift out of 1st. The tranny has a stock torque converter and a Stage 2 Shift Kit. My car has a trickflow stage 1 cam in it as well as Edelbrock heads. I don't know if the stalling part has anything to do with that, but the shifting problem I don't know the issue with that. The transmission shop that installed it drove it not very far or very fast.
91StangGT5.0 is offline   Reply With Quote
Old 11-11-2009, 09:43 PM   #2
OsirisGuy's Avatar
Re: Rebuilt AOD stalls engine in reverse and only has 1st gear
What year is the transmission from, and what year is the car it went into? I think in '94 and '95 the Mustang used the AODE transmission instead of the AOD and the two are not interchangeable.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-11-2009, 10:19 PM   #3
It's an AOD and it came from a 90 GT and went into my 91 GT.
Old 11-11-2009, 10:49 PM   #4
OsirisGuy's Avatar
Well it definitely sounds like the transmission. I believe the internals are also non interchangeable between AOD/AODE/4R70W. If a shop built it, or installed it, I'd take it back to them to get it checked out. Especially if it's been rebuilt. If someone doesn't know how to rebuild it or makes the slightest mistake it can cause many problems.
OsirisGuy is right
2002 Mustang GT
Old 11-11-2009, 10:52 PM   #5
It worked when we pulled it from my friends 90 GT. He had it rebuilt by a place that does nothing but performance transmissions. It had less than 100 miles on it. He took it out because he went with a TKO.
Old 11-12-2009, 05:02 PM   #6
Yea I got it to shift finally. The throttle cable was sticking. I do have another problem though. It will almost stall when coming to a stop because it feels like it's not going back down to first or coming out of gear...
edit: I am also driving it with a stock torque converter and a Trick Flow Stage one came lol....I know that needs to change.
stalls when decelerating 2003stangmachI 1996-2004 Mustang GT 1 11-11-2009 09:17 AM
reverse gear grind chris098 1996-2004 Mustang GT 8 01-21-2008 10:49 PM
Car stalls in drive SeadudeRXP Pre-2005 V6 Mustang 9 12-29-2005 09:40 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 10:08 AM
Sound in 1st gear drichard Pre-2005 V6 Mustang 12 10-10-2003 02:17 PM
08:48 AM
