Identify Roller Motor - Mustang Evolution
Old 11-12-2009, 07:01 PM   #1
Can anyone help me identify the roller cam H.O. 302 from a non H.O.
Lester is offline   Reply With Quote
Old 11-12-2009, 07:22 PM   #2
67mustang97's Avatar
Region: Vermont
Re: Identify Roller Motor
Of course the heads H.O's using the roller rockers, I think the Intake manifold is a little bigger along with the throttle body and injectors and a 351 firing order. I'm sure there's more info but I'm all out lol...
Old 11-12-2009, 07:26 PM   #3
I am trying to find a used motor and I just don't want to get taken.
Old 11-12-2009, 07:38 PM   #4
Region: Vermont
Do you have a motor in mind? If not I'd look for a Lincoln mark 7 LSC those had the 225hp H.O's stock.
Old 11-12-2009, 07:41 PM   #5
I was thinking of a 1987-2003 mustang motor,what year is the mark 7 motor your talking about
Old 11-12-2009, 07:43 PM   #6
I cant find the Thanks button but thanks for replying
Old 11-12-2009, 07:46 PM   #7
Region: Vermont
I had a 87 with the H.O. If you check the firing order to make sure it's a 351 order you should be fine. 1-3-7-2-6-5-4-8
Old 12-24-2009, 05:08 PM   #8
lugthug713's Avatar
I just sold my short block 302 HO. Roller out of a Mark7
lugthug713 is offline   Reply With Quote
Old 01-13-2010, 05:39 PM   #9
V8Demon's Avatar
Send a message via AIM to V8Demon
NON H.O. motors
Base fuel injected 5.0 non H.O. motors were rated at 150-165 flywheel horsepower and between 265-280 ft-lbs of torque depending on the model it was installed in and the exhaust it received (at least, according to Ford).
These motors were in 86-91 Crown Vics/GrandMarq's/Town Cars; '86-87 Continentals; 86-88 T-birds & Cougars; 1986 MarkVII (except the LSC edition -- 1987 - up were all 5.0 H.O.)
How much more restrictive were the non-H.O. parts?
--50 mm throttle body as opposed to the H.O. 60 mm....The upper intake opening is smaller as well.
--The dreaded E6 heads.
--A cam with under .400" advertised lift and less duration than the stock H.O. cam.
--14 pound injectors fed by a 65 lph fuel pump.
To add -- ALL 5.0 motors installed in PASSENGER CARS -- whether H.O. or non H.O. were roller blocks. Truck motors were machined to accept the dogbones for the roller lifters and the hold down plate, but were given flat tappet cams unti 1994 when they switched to Mass Air.
All 5.0's from 1993 on have hypereutectic pistons.
Good luck!
--05 Mustang GT-Low 12's-Whippled!
--87 Cougar 5.0 Trick Flow Heads & Intake-Ed Curtis Cam-Many other goodies-3100Lbs...Low 12's
V8Demon is offline   Reply With Quote
Old 01-15-2010, 06:37 PM   #10
If you can look at the block itself....
below the lower intake look at the lifters. If there is a metal retainer holding them in (a large piece in the valley) it's a roller cam. Individual lifters it's gonna be a flat tappet.
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 01:03 AM
Looking for a Roller Spark Plug Mustang Parts for Sale and Wanted 1 09-09-2008 02:17 AM
Identify this: I dare you Ken The Bar 36 08-31-2005 09:42 AM
Help Identify... Seph The Bar 9 08-22-2004 06:15 PM
07:23 PM
