Replacing U-joints? - Mustang Evolution
Old 10-19-2005, 01:29 PM   #1
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Replacing U-joints?
Hey guys. Well I have a pretty strong belief that my U-joints are worn. When I decelerate my rear end vibrates, im guessing my U-joints are worn and loose, can anyone help me out and try and tell me the basics to replacing them or direct me to a article they know of that talks about doing this, thanks guys!
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 10-19-2005, 08:03 PM   #2
Region: Iowa
Re: Replacing U-joints?
I have bad news for you.
You have a Mustang, and your U-joints need replaced. This will be a very frustrating time for you, and you will probably bleed a little bit. Or a lot. You will probably smash a finger or two, or a thumb and say words that will make your mother cry, your wife/gf blush, and your kids (if you have any) pass out from shock.
But the rest of it aint so bad. If you have a big bench vise, that will help.
The bolts that hold the DS on are 12mm 12pt, if they have never been off they will be tough.
after you jack up your car (and support it securely on jackstands) I would drain the trans or the fluid (just part of it)will leak everywhere when you take your DS out. This will probably be the first thing that makes you cuss.
Take off the DS. If you have a bench vise open the jaws enough so that you can fit the yoke on them.
Tap everything together first to break the rust from the retainer clips for the caps. Trying to get these out will proably make you say bad words too.
Put the yoke on the jaws of your vise and pound away with a hammer on the driveshaft behind the caps for the joint. The effort from doing this will make you swear. A brass hammer, if you have one, is best for this. Otherwise any old BFH will do.
If you do not have a vise, which I did not the first two times I did these, get a large wooden block and drill a hole in it that is slightly larger than the cap. Put that over the hole and take one of you sockets from your crappy $5 (made in some asian country) tool set and wail away on the cap opposite the one on the block.
I forgot to mention that the amount of hammering done, and everything slipping off the wooden blocks frequently, and hitting yourself with the BFH occasionally will make you emit such a plethora of blue words that you will sound like you are doing all the voice overs for a pornographic film.
when the caps come out, make sure you save any needle bearings that are still in decent shape, as you may lose or damage some when putting it back together.
Here are a couple tips;
1- Designate a day to do this your first time. The night before you do this, put your new U-joints in your freezer and leave them there until you are ready to put them in.
2- Strategic application of heat can make your job easier at times.
3- Soak everything with PBblaster the day before you do this, it might even work to put it on a few days ahead of time and keep applying so it has time to soak in.
4- Re-assembly can be much easier if you heat up the yokes and pull the frozen joints out of the freezer just before re-assembly. Be careful about the heating though, does not need to be red-hot, just warm enough (around 150*)
1990 Mustang LX 2.3Turbo
Turbo Swap, 5-Speed Swap,Adjustable Boost valve(set at 15psi), Walbro 255lph(high pressure) fuel pump, 35# Injectors, Garrett T-3 Turbocharger(.60/.63)
4sd4d is offline   Reply With Quote
Old 10-20-2005, 06:24 AM   #3
Hmm alright, it sounds like an all day task, im 17 so I wont have any kid's passing out from shock lol, I think I can do this but I dont, because ive never messed with anything under my car, I know that transmission fluid is in the drive shaft and what not, this would be my first time ever, do you think I can do this? Or maybe you can just come down here and help me out. I know itll cost a crap load for me to take it somewhere and have it done, so im really steering in the direction of doing it myself, I'll try and go for it, thanks for the sweet article you wrote, it should help me out a greal deal because theres alot of crap I didnt think I would have to do when I am going to replace them, i'll probably order the U-Joints soon, ill come back on here and keep you posted, or if I **** anything up ill take a picture of it and ask what did I do wrong, haha. Thanks again man!
Old 10-20-2005, 06:36 AM   #4
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
take pics and do a write up for the site
and to keep from having to take apart the yoke and shaft, you could just buy an aluminum ds. but that's money you may not have
good luck
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 10-20-2005, 05:01 PM   #5
Region: Iowa
I think you can do it, we all had to start somewhere, I did my first u-joints once upon a time too.
There is no fluid in the driveshaft, it is in the transmission, but the DS holds it into the transmission.
As for the writeup, you are quite welcome, it is very satisfying once you fix something on your car and it works so much better afterwards.
I will keep an eye on this thread in case you have questions, if I don't happen to reply shoot me a PM and I will get back to you.
Old 10-20-2005, 08:34 PM   #6
Sweet deal, much appreciated, I love these forums!
Old 10-20-2005, 09:32 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
i love this write up.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 10-20-2005, 09:35 PM   #8
Yeh...the write up cracked me up as well.
Old 10-21-2005, 07:19 PM   #9
Region: Iowa
Thanks guys, I tried to make it informative and entertaining.
It is also pretty true, as far as all the bad words part, when writing this up I remembered back to my first U-joint change.
I had to do it twice withing 6 months. The reason is that when I had the automatic in my first Stang the rear U-joint went out. I replaced it and then shortly afterwards did my automatic to manual swap.
This swap required a shorter driveshaft, so I got it from the donor vehicle. Did the tranny conversion and just a few weeks later, the same Forkin' U-joint went out.
I have done a few others since then. I don't need to swear a blue streak as much anymore, I mostly do it for form now.
Old 10-21-2005, 08:41 PM   #10
Danger Dude's Avatar
U-Joints are a breeze as long as you have ramps and jack stands to raise the entire car or you have access to a lift. Tools required are some brass drifts and a BFH Big F**king Hammer, ring pliers, vise and a socket set. That is all I ever use
Old 11-07-2005, 06:30 AM   #11
SO when your U-Joint went out, we're you experiencing the things that I have happening?
Old 11-07-2005, 08:16 AM   #12
Monkey's Avatar
This is exactly how I did my u-joint swaps. Except I never put the things in the freezer. Might have helped. Did the old socket with BFH trick. Cussed a lot.
My personal favorite part of it was getting the caps off and all the f*cking needle bearings falling out. So it took me about an hour for each cap to get them all lined up and crap. I even thre the BFH and knocked a huge hole in the fence I was next to.
oh, and you don't have to order u-joints. Just go down to AutoZone and get some. Afterall, it is a "Universal" joint
Old 11-07-2005, 09:30 AM   #13
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
that was an awsome write up!
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 11-11-2005, 07:16 PM   #14
Region: Iowa
What happened when my U-joint went out (both times) was as follows;
I would hear a lout thunk from the back of my car when acellerating from a stop, then the noise was gone until stopped again.
Under deceleration there was sometimes a thunk, but always a weird vibration, then a thunk as I brought it up to speed.
Mine was at the extreme end of being worn out, only one of the caps had half the needle bearings in it, the others had dust and parts of bearings. One just had some rust that may have been part of bearings at one time.
Bad ball joints on a 2007 liteboxz 2005-2010 Mustang GT 1 08-28-2009 08:48 AM
Steeda bumpsteer ball joints SOCK 1979-1995 Mustang GT 2 09-09-2008 01:37 PM
bearings/ball joints in the rear tigerfan2771 Pre-2005 V6 Mustang 5 08-06-2008 07:19 AM
replacing a mirror mexor Mustang Audio & Video 14 03-07-2004 07:48 PM
U-Joints or ADS? Ken Pre-2005 V6 Mustang 1 05-06-2003 01:32 PM
07:47 PM
