Problems With Ford Mustang '95 - Mustang Evolution
Old 11-23-2009, 10:04 PM   #1
I have a 1995 Ford Mustang GT with a 5.0 V8 302L Engine with an Automatic Transmission. Recently, my car has been experiencing numerous problems with the Engine putting. When you go to accelerate, you have to punch it to 3000 RPM to make the car run somewhat normal. What do you believe the problem is? Do you think is my fuel pump/fuel injector?
superman93 is offline   Reply With Quote
Old 11-23-2009, 10:45 PM   #2
outlawfrog's Avatar
Re: Problems With Ford Mustang '95
Start with the simple stuff.....like fuel filter....check your plugs and wires also. Check all of your vaccum hoses for cracks/breaks and to make sure some have not came loose.
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 11-24-2009, 06:04 AM   #3
Can you be more specific about what the car is doing? Is the engine stumbling, or does it take 3000 RPM to get the car to move? Reason I ask, a friend at work with an automatic had to rev up quite high to get the car to move. Reason? A clogged transmission filter. Pull the tranny dipstick and see what the fluid looks like. It should be bright red; if it's dark going towards black, you need to have the tranny flushed and refilled with new fliud & a new filter. Even if this doesn't fix your problem, it's a maintenance item that often gets overlooked.
MetallicMist is offline   Reply With Quote
Old 11-24-2009, 10:35 AM   #4
outlawfrog's Avatar
Good point.....never hurts to do the regular maintenance. Things like tranny fluid and filter, fuel filter, all other fluids and filters.....should be checked and replaced on a regular basis, just like oil.
Old 11-24-2009, 12:09 PM   #5
OsirisGuy's Avatar
Make sure all the regular maintenence is up to date before going crazy.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-24-2009, 08:58 PM   #6
I replaced the fuel filter and everything. No, it doesn't take 3000 rpms to make the car go. It takes 3000 rpms to make the car stop putting as much as it does. The car runs good going down the dirt road. When I hit pavement and hit the gas the car putts going under 3000 rpm and then when I punch the gas and hit 3 rpms the car stops putting.
Old 11-25-2009, 07:39 AM   #7
as said above, tune up time.
plugs, plug wires, fuel filter, injectors cleaned, maybe run seafoam in the car, distributor replaced, clean the MAF sensor and IAC sensor (idle by pass valve) and reset timing.
Old 11-25-2009, 09:04 AM   #8
ok i will try that and get back to you guys thanks
Old 12-22-2009, 05:41 PM   #9
I have figured out what was wrong with my car. I ran a scan and found out that the O2 sensor was bad. So I went and bought an O2 sensor for the right side and took it for a test drive. The car is now running great and I believe I have solved the problem! Thanks for your help!
Old 12-22-2009, 07:07 PM   #10
Good deal! Glad you are running right again.
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
Problems with 1991 Mustang GT wmsoccer28 1979-1995 Mustang GT 10 08-20-2007 09:48 PM
mustang problems?? MarcyWK Pre-2005 V6 Mustang 7 05-08-2006 12:54 PM
1998 Ford Mustang Starting Problems redv6stang Pre-2005 V6 Mustang 4 09-25-2005 02:17 PM
What problems have you had with your mustang? mstnglvr The Bar 20 07-09-2004 10:02 AM
01:55 AM
