Got the GT40's,now a bunch of questions..... - Mustang Evolution
Old 10-26-2005, 08:56 AM   #1
Vinnietbird's Avatar
I got the GT40's yesterday,and there are no smog holes in the back of the heads.I still have the smog equipment hooked up.The car is an '88 T-Bird with a 5.0 H.O.,Explorer intake.When I install the GT40's,do I just toss out all of the smog equipment?Do I keep the EGR valve on the spacer hooked up/plugged in?Can I toss out the smog pump,smog lines on the passenger side of the engine and smag tube to the H-Pipe?I obviously won't be using the tube that runs from one head to the next in the back of the engine.Where do I go from here with this project????
Vinnietbird is offline   Reply With Quote
Old 10-26-2005, 10:17 AM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Got the GT40's,now a bunch of questions.....
Dump the smog pump... now you dont need it.
I like toys
Old 10-26-2005, 11:05 AM   #3
Thanks Zim.What about the EGR valve and associated wiring?
Old 10-26-2005, 11:07 AM   #4
Zim
Zim's Avatar
Everything that had to do with the smog pump on my car is gone from the previous owner so Im assuming you wont need that either. There was a little pump looking thing sitting in the back of my engine compartment that I had no clue what it was for. I kept asking people and eventually someone said it was form the removed smog equipment... just leftover nonesense.
I like toys
Old 10-26-2005, 11:22 AM   #5
10-4.I'm aquiring the rest of my needs before I get started (gasket set,plugs,new plug wires,etc).I want my 'bird to be a strong runner (already is,but more power can't hurt),yet look factory.When I make any mods,I try to keep them clean and use Ford bits and pieces.
Old 10-26-2005, 12:42 PM   #6
Zim
Zim's Avatar
sweet... did you get the GT40p's?
I like toys
Old 10-26-2005, 01:09 PM   #7
I got the GT40's,not the "P" heads.They are still a major improvement over what I have.I ended up trading a set of E7 heads and 2 intake manifolds for them.He was asking $100 if I pulled them myself (no problem).They only have 23,000 miles on them,and they are CLEEEEEEAN.I'm not in a hurry to swap them.I'll take my time and,like I said,acquire my parts and get my plan together for the A/C removal,and smog equipment removal,belt routing,etc.I want to be ready.No surprises (at least no big surprises).I'm watching for a good set of headers on E-Bay,along with a couple of other items.
Old 10-26-2005, 01:11 PM   #8
Sounds good man, it's good to see people taking their times and planning out their mods to make sure it works right the first time and looks good!
Old 10-26-2005, 02:00 PM   #9
Yep,I agree.It sucks jumping into it and having to spend most of your day jumping back and forth to the parts store for little items.I want everything ready to go,so I can spend a few hours doing the swap,and still have time in my day to drive it and enjoy the new horsepower.
Old 10-26-2005, 07:10 PM   #10
MonteCitan's Avatar
hey man.. the gt40s are okay.. mine aren't Ps either.. and my car ran a 12.8@107 with these.. (fully ported/honed however, with larger valves installed..) and I'm hoping it will flow enough air for my 331..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 10-26-2005, 08:33 PM   #11
I've got to be careful,I have flat top pistons.I'll leave the valves as they are.Porting,now that's another story.I may do a little porting and polishing.
Old 10-27-2005, 04:55 PM   #12
fast64's Avatar
when you delete your EGR setup, this will keep your car from throwing a CEL: http://fordfuelinjection.com/index.php?p=61
also, if you need a Smog idler pulley (you might not, but I had to because the smog pump bracket bolts between the supercharger and alternator brackets), ASP has one: http://store.summitracing.com/defaul...=egnsearch.asp
GO BRAVES
Old 10-27-2005, 05:17 PM   #13
Thanks a lot.I'll probably be needing that.
Old 02-27-2006, 10:14 PM   #14
Well,a tiny update.Since my last post on this subject,I have got a new fuel pump,65mm throttlebody and spacer,1 5/8 shorties,A/C eliminator (I installed that),and now I'm having some worries.Will the GT40 heads work with my flat top pistons????I hear "Yes',and I hear "No".I can't seem to find a defineative answer.I plan on keeping the factory cam.Any ideas?
Old 03-02-2006, 05:22 PM   #15
MonteCitan's Avatar
my milled gt40s and a mild cam worked with my stock flat-topped pistons
Old 03-03-2006, 05:06 AM   #16
Thanks Montecitan.I am getting closer to the swap eveyday.I got my new fuel pump and TPS,I've got the heads,65mm t-body and spacer,1 5/8 shorties,and hopefully VERY quick,I'll have an off road h-pipe.All of those parts are literally sitting on my workbench.I'd like to get an adjustable fuel pressure regulator.One piece at a time,though.
Old 03-03-2006, 07:01 AM   #17
MonteCitan's Avatar
I got the mallory adjustable regulator.. $54... works great for me.. 35-65 PSI range.. only issue is its powdercoated RED but I can deal with it..
Old 03-03-2006, 10:14 PM   #18
Thanks again.I'll check into one of the Mallory units.I may check E-Bay and see what I can find.
Old 03-03-2006, 10:25 PM   #19
bbunt302's Avatar
No matter what cam you decide to go with, always check PTV clearance yourself when you assemble the motor. Every motor is built ever so slightly different. What clears on one may not clear on another.
Either way, good luck with the build.
Scary stuff.
Old 03-04-2006, 05:13 AM   #20
Thanks a lot guys.I'll do a PTV chack just in case.I'd hate to shell out my engine after going through what I have just to get it and associated parts for it.
What a bunch of babies Brent The Bar 12 08-28-2008 10:37 AM
Wonder How Much they Paid these Crazy Bunch bluemustang The Bar 15 09-08-2006 11:32 AM
Got a bunch of parts. Tbird232ci Pictures and Videos 11 03-21-2006 02:42 PM
Bunch of Ebay'd Stuff... Junior2561 Mustang Parts for Sale and Wanted 1 11-08-2004 11:50 AM
You want a bunch of vids? Rellik The Bar 4 09-19-2003 08:46 PM
10:19 AM
