87gt no start... were does this wire go? - Mustang Evolution
Old 11-09-2005, 08:34 PM   #1
for an 87 on the negative battery cable there is a small wire that branches off and according to the wiring schematic it goes to the eec module....there is no way it can reach the computer........does it go on the firewall?...were?....right now im stuck on stupid and need help!......
gankSP is offline   Reply With Quote
Old 11-09-2005, 09:49 PM   #2
Re: 87gt no start... were does this wire go?
Can you get a picture of the wire and surrounding area?
Old 11-09-2005, 09:52 PM   #3
yup'...but its dark and tommorrow is another day.....gotta run out and get batteries for the diggi.
Old 11-09-2005, 10:19 PM   #4
Tbird232ci's Avatar
if it comes off of the negative terminal, its for the EEC ground
there should be a connector somewhere for it, unless your wire is cut or broken
if its what i think it is, the car fires up, then dies quickly doesnt it?
Old 11-09-2005, 10:30 PM   #5
nope the starter doesen't crank.......new starter and stater relay before engine dissasembled (i know it works) ...my wiring harness it pretty much squared away....except for trans linkage and O2 sensors car.... is currently in neutral.... and was in park...tried'em both......i was told it is the main ground for the comp. and is located in between the battery and starter relay ...the end of the cable was cut and much like alot of my wiring from the previous owner
Old 11-10-2005, 10:16 AM   #6
Tbird232ci's Avatar
im going to check my EVTM's a bit and see if i can come up with. But the main EEC ground doesnt go to the starter selenoid, it runs directly to the battery. I found this out the hard way in my own car.
when you try to start the car, does the lights dim, and your gauges react accordingly?
Old 11-10-2005, 01:00 PM   #7
lights go on and dim a little....gauges do a full sweep once then stop....and all i hear is the wind between my fingers and ignition.....
Old 11-10-2005, 01:15 PM   #8
Tbird232ci's Avatar
Have you tried bridging the starter selenoid with two screw drivers? to make sure the starter isnt the problem?
Old 11-10-2005, 01:31 PM   #9
i replaced the starter before i dissasembled the engine...and the relay....i tryed to jump the relay with and ajustable wrench.. instant weld! replaced the relay again ......i touched the starter cable to the possitive battery terminal and it cranked....im still "lost in the sauce"
Old 11-10-2005, 02:29 PM   #10
Tbird232ci's Avatar
you have a test light, and a helper? the wire that goes to the starter selenoid, the thin one that attachs to the thin post is the signal from the ignition circuit, test that wire and see if it gets power while someone tries to crank it, if it gets power, who knows what the problem is
Old 11-10-2005, 02:45 PM   #11
yup.....i gotta clear my head out and take a brake......1st thing tommorrow and i will let you know the results
power wire? tylbrune Mustang Audio & Video 2 02-16-2010 12:10 PM
Drive By Wire Rollinthundr General Car Discussion 9 09-05-2006 02:49 PM
Wire tapping... DarkShadow The Bar 11 05-13-2006 09:52 PM
wire loom... mustangmare Mustang Audio & Video 20 11-21-2004 01:34 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
04:09 PM
