5.0 and 4.6 questions - Mustang Evolution
Old 12-27-2009, 08:47 PM   #1
Im looking at the 94-98 mustangs and they have some of them with the 5.0 and some with 4.6 motors but they both have the same the same hp and torque rating just doesnt seem right anybody know the actuall rating if any different. also which one last longer or is more durable . im interested in the 302
Cblaze is offline   Reply With Quote
Old 12-28-2009, 12:55 AM   #2
upton7's Avatar
Re: 5.0 and 4.6 questions
96-98 = one of the weakest mustangs ever the 5.0 can make alot of horsepower and they are cheap and easy to build. Stock horsepower rating on a car over 10 years old doens't mean much to me. When i buy a car that age i'm definatly rebuilding it no matter what.
Old 12-28-2009, 07:52 AM   #3
i hopefully can find a one owner of the 302.there is a few around here that has set in garages since they were new instead of outside and not to much over 100k on them.but by the time i get the money for one they may not be one with low mileage.my uncle has a fox body with a 302 and its quick .i like the bore and stroke of the 302 after looking at it
Old 12-30-2009, 06:34 PM   #4
i have read the 94-95 5.0 has 215 hp and 285 ft lbs tq is that right it says the exact same for the 4.6
Old 01-01-2010, 09:52 PM   #5
lugthug713's Avatar
ya thats the power but the 302 is cheap to get add on power, if on a budget get heads and intake on 96 97 explorer and swap and thats a good improvement for like $100 out of a you pull it junk yard. But if your gana boar and stroke get alumion. heads you'll be 300+ if done right
lugthug713 is offline   Reply With Quote
Old 01-04-2010, 09:28 PM   #6
5.0's are MUCH easier to get power from and MUCH cheaper. im biased though, im a 95 owner
iamdat is offline   Reply With Quote
Old 01-13-2010, 03:43 PM   #7
V8Demon's Avatar
Send a message via AIM to V8Demon
If it only has 20K miles on it, I doubt you'd be rebuilding it......
Mileage and proper maintenance have more to do with wear & tear on mechanical components than how many times the Earth has went around the Sun.
That being said, what are your goals for the car? Intended use? Desired power level?
--05 Mustang GT-Low 12's-Whippled!
--87 Cougar 5.0 Trick Flow Heads & Intake-Ed Curtis Cam-Many other goodies-3100Lbs...Low 12's
V8Demon is offline   Reply With Quote
Old 01-14-2010, 09:31 PM   #8
iwannagofast's Avatar
The only prob. i see with the old 5.0s is the T-5 tranny.
iwannagofast is offline   Reply With Quote
Old 01-15-2010, 10:09 AM   #9
its simple, the 5.0 is the better choice stock vs stock. The 4.6 is not as good of a motor IMO. The tq on the 5.0 is more also. The 5.0 can be made non slow much cheaper than the 4.6 can.
Old 01-16-2010, 11:19 PM   #10
Zebs5408's Avatar
YEPPPPP
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-17-2010, 01:06 AM   #11
big show 98's Avatar
Another vote for the 5.0
big show 98 is offline   Reply With Quote
Old 01-17-2010, 01:44 AM   #12
MonteCitan's Avatar
Another vote for the 5.0, may be same HP rating, but the torque band > the 4.6
And there's nothing wrong with the T5s used in the GTs, very smooth shifting.. and mine took a beating
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-17-2010, 02:45 AM   #13
True, just need to know how to shift it.
Old 01-17-2010, 03:27 PM   #14
5.0 (94-95) all the way. They take a beating and run for a long long time. Finishing up rebuilding one in a Bronco that has over 220k on the odo. Shortblock looked fine, just blew a headgasket. Did a little port job on the heads and it's going right back together for more abuse.
Old 02-19-2010, 06:13 AM   #15
lugthug713's Avatar
I like my 95 GT. If your looking at a 94-98 stang i would go 5.0! But if I had to buy another stang today it would be a 03 04 Mach 1 BC they already have 300 HP and they look badass. And you can get one for $12000 these days. I like the PI 4.6 I had one and it was faster then my bolt on 5.0 and it was stock
Old 02-19-2010, 10:25 AM   #16
5.0 for fast on a budget, plus the SOHC 4.6L in 96-98 is simply horrid without a PI swap
Old 02-24-2010, 11:28 AM   #17
lugthug713's Avatar
but i do have a set of 4.6l non PI heads cheap and intake manifold with tb all stock
Old 02-24-2010, 02:21 PM   #18
upton7's Avatar
I wouldn't buy a 10 year old car with 20k miles on it and if i did i definatly would rebuild it anyway
Old 01-12-2011, 10:01 PM   #19
94 Mustang GT's Avatar
Both 5.0 and 4.6 are OUTSTANDING engines!!! Very strong! 4.6 crank bearings can easlily look new with 200,000 miles. the 4.6 is obd II easier mods ( can also plug n play) and the 4.6 is also ohc! 5.0 easier to go faster! 5.0 more mechanical. 5.0 great hp for money spent.
94 Mustang GT is offline   Reply With Quote
I need help with a few questions xjlxking 2005-2010 Mustang GT 14 02-22-2010 01:38 PM
Few questions SaturnMan8227 Pre-2005 V6 Mustang 21 07-10-2008 02:43 PM
two questions..help! 02whitemustang Pre-2005 V6 Mustang 7 08-28-2006 10:51 PM
Questions cms09071987 Pre-2005 V6 Mustang 14 06-26-2005 12:28 PM
gt take-off questions blk2kconvstang Pre-2005 V6 Mustang 7 03-22-2004 08:02 AM
08:27 PM
