bad coolant leak - Mustang Evolution
Old 01-04-2010, 10:07 AM   #1
bad coolant leak
i have an 89 5.0 and it seemed to bleeding coolant and all signs pointed to the radiator so i just finished replacing the radiator and feed/return hoses and when i turn it on i notice coolant running out of the side of the block like a faucet as if a hose or bolt popped out...it is leaking driver side under the headers, freeze plug is still in place caked with dirt so it wasn't that...any ideas as to what might have come off/unplugged?
jmachleit is offline   Reply With Quote
Old 01-04-2010, 12:34 PM   #2
Re: bad coolant leak
did you remove/ replace/ mess with the water pump? Check around it for a leak source.
Old 01-04-2010, 01:30 PM   #3
never touched the pump...it is literally like a faucet from under the driver side header
Old 01-04-2010, 03:19 PM   #4
there may be a plug in the block that you can unscrew over there~ no idea why it would have just now started doing it though.
Old 01-04-2010, 04:13 PM   #5
Is there a line that is supposed to go to the heater or something? The previous owner ripped out all heating and ac
Old 01-04-2010, 09:26 PM   #6
all the heater stuff is on the passenger side. have a buddy pour water in so you can get a better look yourself. sure it aint a waterpump?
iamdat is offline   Reply With Quote
Old 01-04-2010, 09:37 PM   #7
v6stang04's Avatar
have you had any cold spells in your area. you couldve had some water freeze and it then blow one of your gaskets. if its a tube connecting to the block, use some die and find the exact spot of where the leak is.
v6stang04 is offline   Reply With Quote
Old 01-05-2010, 09:23 AM   #8
lucky me forgot to take the keys out of the ignition and the battery is dead, once i get it up and running again i will take pictures, thanks for your help thus far
Old 01-13-2010, 04:31 PM   #9
V8Demon's Avatar
Send a message via AIM to V8Demon
There is. It has an allen head on it and is meant to drain the block before you pull the motor. There is one on each side. The driver side one is not too far from where the oil pressure sending unit threads into the block.
--05 Mustang GT-Low 12's-Whippled!
--87 Cougar 5.0 Trick Flow Heads & Intake-Ed Curtis Cam-Many other goodies-3100Lbs...Low 12's
V8Demon is offline   Reply With Quote
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Coolant Leak floridamba Pre-2005 V6 Mustang 0 04-04-2007 08:40 PM
When things go bad... they really go bad for some people Brent The Bar 8 12-13-2006 09:31 PM
coolant leak inside car Racin02GT 1996-2004 Mustang GT 8 06-19-2006 06:19 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
12:20 PM
