fuel pumps don't come on - Mustang Evolution
Old 01-02-2006, 12:16 AM   #1
Send a message via Yahoo to dana
I had an 86 mustang 5 speed and put the gt40 motor with aluminum heads, gt40 manifolds, s trim vortech supercharger which came with the msd boost ****** and fmu, msd ignition, the mass air conversion kit (came with 24 lb injectors 70mm mass air sensor and i think a cobra computer, and a bunch of other stuff. That car was hit in the rear and totalled so I got a 91 mustang and transferred everything over to it. It was an automatic when I got it now it's a 5 speed. anyway when i turn the key on the fuel pumps don't come on. anyone know what would cause this? I unplugged the fuel pump relay and jumped across 2 of the wires and they came on so i put a switch between those 2 wires so I can drive it till I figure out why they don't come on with the key. anyone have any suggestions?
dana is offline   Reply With Quote
Old 01-02-2006, 02:03 AM   #2
Re: fuel pumps don't come on
ok, this may be a stupid question but sometimes the obvious is what bites you the hardest.
Did you try swapping relays to see if the relay was just bad?
sportsoutlaw is offline   Reply With Quote
Old 01-19-2006, 06:11 AM   #3
Sounds like you need to replace the fuel relay..
Eric
1990 Mustang GT
9.75 @137.13
Check out this forum for AOD's: Click Click Racing Forums
My Homepage
RdRunnr is offline   Reply With Quote
Old 01-19-2006, 07:24 AM   #4
fast64's Avatar
check under the carpet in the trunk, right behind the left taillight. There is a fuel pump cut off switch. try pushing the red button down, it should fix your problem if it has been triggered.
GO BRAVES
Old 01-21-2006, 02:59 AM   #5
already did all that and they still don't come on.
Old 02-15-2006, 09:52 AM   #6
FakeSaleen's Avatar
neutral kill switch for the automatic trans
FakeSaleen is offline   Reply With Quote
Old 02-18-2006, 02:36 AM   #7
i have a manual transmission. Could it be that that part of the ecm isn't working. If so that very well could be what it is.
Old 02-18-2006, 06:16 PM   #8
Joel5.0's Avatar
....or an open relay wire going to pin 22 in the ECM, or an open wire between the EEC relay and the FP relay (they share Ign On voltage). My 2.
1986 Mustang GT w/T-Tops :angryfire
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66 Small Port Heads, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears, LS Overhaul, Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), New Valve Springs (FRPP, done), Subframe Connectors (MM), Caster/Camber Plates (MM), T-Top weatherstriping and rear braces bodywork :cussing:
Joel5.0 is offline   Reply With Quote
Old 02-19-2006, 12:45 PM   #9
I dont think that will fix his problem.....no to argue though. If the fuel pumps come on while jumpin wires that means the problem is from the relay to the ignition switch...not to the pump.
fsst93gt is offline   Reply With Quote
Old 02-19-2006, 04:12 PM   #10
fast64's Avatar
that is true. sounds like a relay problem then.
GO BRAVES
Old 02-22-2006, 02:08 AM   #11
i've unplugged the fp relay and took 2 of the wires and jumped across them and they came on so for now i put a switch between those 2 wires and manually turn the pumps on before i start it then off when i stop. To me it seems like i should have way more power than i do overall for everything that the car has in it.
Old 02-22-2006, 09:21 AM   #12
fast64's Avatar
have you tried putting another relay in so you don't have to use the switch?
GO BRAVES
Old 02-23-2006, 01:03 AM   #13
yes. I've also replaced the eec relay
Old 02-24-2006, 06:06 PM   #14
Joel5.0's Avatar
Dana;
Check the wiring diagram attached (Courtesy of Veryuseful.com) for the '91, it will help you in tracing the wires. Click image for larger version
You should have voltage all the time at the Pnk/Blk wire. Voltage at the Red wire with Ign On only. Otherwise, need to trace either back for an open to the fuse link or the EEC relay.
Dk Grn/Yel wire goes to the FP, no problem there.
Now, the Lt Blu/Org is the wire that gets the ground from the ECM to activate the relay, thus the FP. Check it out bet it's a wiring SNAFU. LUK
SVT focus fuel pumps whipster24 Mustang Parts for Sale and Wanted 3 08-24-2007 01:28 PM
Vette owner pumps coolant into his oil... MonteCitan The Bar 15 03-15-2007 08:54 PM
Fuel Pumps pres_slappy Classic Mustangs 1 07-17-2006 03:24 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
electric pumps el cheapo Pre-2005 V6 Mustang 4 07-21-2003 11:46 PM
09:46 PM
