wat do i need - Mustang Evolution
Old 01-12-2010, 06:12 PM   #1
wat do i need
my 88 is a 5 speed im tryng to go auto am looking at the aode trans but wat else do i need to convert would it be a direct swap wat parts do i need o jea i got a f303 cam on my fox specs is duration226/226 lift 512/512 how big should i go on my stall
juced302 is offline   Reply With Quote
Old 01-12-2010, 08:51 PM   #2
big show 98's Avatar
Re: wat do i need
Not 100% sure if the flexplates are the same, if not get one for a 94-95gt. You will need to install a switch for the push button overdrive. Someone else will need to give you the scope on which shifter to use. At least run a 2800-3200 stall. A 4r70w for a push rod engine would be a better choice, just a thought. Have you converted to mass air?
big show 98 is offline   Reply With Quote
Old 01-13-2010, 12:03 PM   #3
Re: wat do i need
from wat i kno 88 up are mass air an 87 down are not . i found 2 foxbodys at the junk yard an they were both auto i think one was a 89 an 92 but i didnt check if they were a.o.d.e or a.o.d i kno the a.o.d.e is electric would that be harder to swap an the aod easier cuz is mechanical o im i wrong?
Old 01-13-2010, 04:20 PM   #4
V8Demon's Avatar
Send a message via AIM to V8Demon
Re: wat do i need
FWIW -- are you running that F-cam on stock heads?
--05 Mustang GT-Low 12's-Whippled!
--87 Cougar 5.0 Trick Flow Heads & Intake-Ed Curtis Cam-Many other goodies-3100Lbs...Low 12's
V8Demon is offline   Reply With Quote
Old 01-13-2010, 05:13 PM   #5
Re: wat do i need
yes i am running the fcam an yea with stok heads
Old 01-13-2010, 10:43 PM   #6
V8Demon's Avatar
Re: wat do i need
That's A LOT of cam for e7 heads. That cam makes peak power past the RPM point where E7's stop breathing....
Old 01-14-2010, 03:32 AM   #7
Re: wat do i need
Only the 88 California cars had mass air. Don't go with the AOD find an AODE or 4r70W. The switch isn't hard to hook up. The 89-92 cars in the junkyard are AODs. If you don't have mass air that 89 will make a perfect donor.
Old 01-14-2010, 01:39 PM   #8
Re: wat do i need
well i am from california an mine is mass air . so whats wrong wit a AOD an were can i get a 4r70w wat car an is the driveshaft the same lenght
Old 01-14-2010, 08:13 PM   #9
Re: wat do i need
The AOD is weak & a power robber. You can get a 4r70w from a 98 v6 stang or v8 explorer, not sure of the year model. The driveshafts are the same lenght. The aod & aode use different shaft yokes than the 4r70w. ( not 100% sure)
Old 01-15-2010, 12:30 AM   #10
Re: wat do i need
so what u telling me i can get the tranny from a explorer u dont think is from a 97 explorer those came with a 5.0 thers a 97 explorer with a 5.0 engine close by in the yunkyard that me an my buddy got that upper an lower manuful for 50 bucks very very good deal. u can say a gt40 manuful he send it out to get ported
Old 01-15-2010, 04:25 AM   #11
Re: wat do i need
Ask the junkyard owner to look that explorer up in his data base to verify the transmission type. If you buy it I would have it looked over before installing it to make sure it's in good condition.
Old 01-15-2010, 05:02 PM   #12
Re: wat do i need
well how many types are ther
Old 01-15-2010, 05:56 PM   #13
V8Demon's Avatar
Re: wat do i need
a PROPERLY set up AOD robs no more power than an E or 4r.
First an second gear are a little longer, but you can swap out the guts.
Weak point in the AOD is the input shaft. You can get a hardened one through many aftermarket vendors.
Old 02-19-2010, 01:08 PM   #14
lugthug713's Avatar
Re: wat do i need
just trade a guy who has a auto that wants a 5sp
lugthug713 is offline   Reply With Quote
a.o.d trans but wat torqe conveter juced302 1979-1995 Mustang GT 6 01-25-2010 12:34 AM
i have around $800...wat shall i get next? 98MustangGT 1996-2004 Mustang GT 12 07-20-2007 09:50 AM
Wat size tire horess05 Mustang Wheels & Tires 2 05-21-2004 10:40 PM
12:27 PM
