my car dont turn on - Mustang Evolution
Old 01-14-2010, 06:05 PM   #1
my car dont turn on
was up guys like 2 days ago i took out my 88 fox to give it a wash. i turned it on an took it out of my garaged an parkd it after i was done washing it.i tried to turn it on an it wouldn crank an it never turn on. my battery an alternator are good but wen i turn the key ignition on back to listin to some music an what i ever i touch as in try to turn on my head lights or roll up my windows everything shuts down what u guys think it is i have tried to jumpstart it an it just tics
juced302 is offline   Reply With Quote
Old 01-14-2010, 06:22 PM   #2
upton7's Avatar
Re: my car dont turn on
well if accesories won't work its either battery all the fuses or something else electrical if it won't start and your for sure battery and alt. are good it might be the starter.
Old 01-14-2010, 06:23 PM   #3
upton7's Avatar
try cleaning the battery terminals and the cables there might be corrosion under the wire insulation try either pulling it back or cut it to see if there is battery corrosion on it.
Old 01-14-2010, 07:36 PM   #4
my batery is good thers no corrosion an my alternator is good an my starter is bran new but ill still check it tho an a month ago i swap my stock heads to ported stock heads an every time i would punch it alot of smoke would kum out i kno when u dont have cats smoke kums out but mine cums out alot i can even see inside my car thats how much it cums out an one day i just open the cap were u port the oil in the cap was full of white Gell an i checkd my dipstik an ther was white gell ther to. wat those that mean blown head gaskets or my block is crack an wen i use my car it always needs coolent the next day
Old 01-14-2010, 08:57 PM   #5
Scut95's Avatar
Sounds like you head gaskets are blown. You can put dye in the oil and use a black light to see where it comes out. It will even show up in the coolant too if it gets in there.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 01-15-2010, 01:19 AM   #6
yea they are blown im just gona put my stok ones bak an save up for some afr's or trickflows 185 thanks
Old 01-16-2010, 11:22 PM   #7
Zebs5408's Avatar
hows thangs looking?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
DONT let your friends drive your car SpectorV The Bar 26 01-03-2005 09:58 PM
Turn signals robert0803 Pre-2005 V6 Mustang 7 09-30-2003 11:52 PM
sorry rellik you dont have the best pacific green car nemore mexor The Bar 48 09-08-2003 10:00 PM
My turn: Rellik The Bar 16 08-09-2003 11:39 AM
03:59 AM
