Goodies? - Mustang Evolution
Old 01-13-2006, 05:17 PM   #1
Goodies?
The car is a 89 lx coupe with the t-5 tranny. I have 24lbs injectors, morso ram/cold air intake, under drive pulleys, msd everything ignition, 75mm mass air, hypertech chip, 3.73's, x-pipe going into dual flowmasters, aluminum rad and short throw shift kit. i want to add electric fan, high output alternator and a new fuel pump but i don't know what size of pump i should get?. still fairly new to this, is their anything i should change or add to make everything work right?
Clay89lxcoupe is offline   Reply With Quote
Old 01-13-2006, 07:28 PM   #2
Bane-'s Avatar
Re: Goodies?
a 155 lph fuel pump would be good, plenty for near stock with still alot of room to grow.
Old 01-15-2006, 08:32 AM   #3
Tbird232ci's Avatar
Re: Goodies?
id go 190 personally
Old 01-16-2006, 10:09 AM   #4
Re: Goodies?
190 over the 155? will the 190 make me run to rich? or does it not matter, the injectors will only shoot so much fuel? yet again new to this stuff.
Old 01-16-2006, 10:23 AM   #5
Re: Goodies?
Fuel pump will not cause you to run rich, only bigger injectors if not tuned properly.
Old 01-16-2006, 03:24 PM   #6
Tbird232ci's Avatar
Re: Goodies?
I have a 255lph high pressure pump in my turbo coupe, which is a 4 cylinder
the only things that determines your fuel mixture is your base pressure, injectors, and tune, the pump only supplies the fuel
i say go with a 190lph because you can get away with running mild forced induction with a 190lph, in case you ever go with say a 6psi blower down the road
Old 01-17-2006, 12:26 PM   #7
Re: Goodies?
Thanks for the info everybody
Old 01-19-2006, 03:44 PM   #8
Re: Goodies?
I'd get a 255...then you would never have to worry about upgrading down the road if you did some motor work or added a power adder.
Eric
1990 Mustang GT
9.75 @137.13
Check out this forum for AOD's: Click Click Racing Forums
My Homepage
RdRunnr is offline   Reply With Quote
Some new Goodies for the 05... Y2E0L0L5OGWT 2005-2010 Mustang GT 12 10-01-2007 10:11 AM
couple of goodies for the 90 Bane- Pictures and Videos 7 05-11-2006 02:07 PM
goodies that should be here by end of week tedness The Bar 5 06-27-2005 04:12 PM
Bought a couple goodies today Monkey The Bar 18 01-21-2005 12:38 AM
Help me find the goodies to make my mustang look like this: Nimitz Mustang Audio & Video 14 08-04-2003 01:06 PM
11:06 PM
