T-56 for fox? - Mustang Evolution
Old 01-24-2006, 07:48 PM   #1
Send a message via AIM to Can'tCatchMe Send a message via Yahoo to Can'tCatchMe
T-56 for fox?
Hey I was looking through the G-force catalog and saw the T-56. I want to buy one but I don't know if they make a version that will fit into a fox. Anybody know? thanks!
Can'tCatchMe is offline   Reply With Quote
Old 01-24-2006, 09:07 PM   #2
Bane-'s Avatar
Re: T-56 for fox?
ford sells one and d&d sells a kit aswell, might be one or two more im missing.
Old 01-24-2006, 09:17 PM   #3
bbunt302's Avatar
Re: T-56 for fox?
I'm not sure if G-Force does, but I know there are other places that offer entire swap kits for the T-56 into a fox. It's been done many times before, but it can be a bit pricey (nearly 3g's at the minimum). The swap requires a shorter driveshaft, different crossmember, and extending a couple of wires. Also, if you get the Viper version of the T-56 (which I would recommend due to the .50 6th gear), you'll need a 26 tooth clutch. Not sure what other versions of the tranny require.
PM me and I can give you a link to a kit.
Scary stuff.
Old 01-25-2006, 03:57 PM   #4
Re: T-56 for fox?
the only thing a 6 speed is good for is shifting to another gear (the ford spec) it may be better for autox... but 99% of fox owners want to go in a straight line.
Old 01-25-2006, 04:11 PM   #5
fast64's Avatar
Re: T-56 for fox?
I agree, big waste of money
GO BRAVES
Old 01-26-2006, 08:11 AM   #6
Re: T-56 for fox?
worse gearing, heavier tranny, etc etc....
Old 01-26-2006, 08:48 AM   #7
bbunt302's Avatar
Re: T-56 for fox?
If I build a coupe, I'm gonna put a T-56 in it. Simpy because you can get the Viper spec with 2.66/1.78/1.30/1.00/.74/.50 gearing, throw in some 4.10 gears, and have a nice closely geared transmission with a ridiculously low overdrive gear. Not to mention they'll handle 650 lb-ft of torque.
Scary stuff.
Old 01-26-2006, 09:11 AM   #8
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: T-56 for fox?
The F-Bodies and 'vettes had the .50 2nd overdrive, too. I knew a guy with an 6-speed LT1 TA who ran 4.56 gears.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 01-26-2006, 10:28 AM   #9
Re: T-56 for fox?
man... ford should have done the same...stupid ford
Old 01-26-2006, 11:41 AM   #10
Bane-'s Avatar
Re: T-56 for fox?
yea I would run atleast a 4:56 rear gear with a 6spd with its overdrive being so low. Screams off the line and still gets decent gas mileage lol
Old 01-26-2006, 04:33 PM   #11
Re: T-56 for fox?
thanks for your help guys, if I got a T-56 tranny from G-force instead is there anyway to get the driveshaft, crossmember, speedo cable, etc. by themselves without purchasing the trans?
Old 01-26-2006, 05:07 PM   #12
bbunt302's Avatar
Re: T-56 for fox?
Probably so, just give them a call and see what they say. I doubt they'd turn down a sale though.
Scary stuff.
Old 01-26-2006, 05:08 PM   #13
Tbird232ci's Avatar
Re: T-56 for fox?
The driveshaft can be shortened at a driveshaft shop, you have to go into the truck industry to find a place to do it.
The crossmember can also be made. The speedo cable might be hard to get.
Biggest problem is cost. A Ford T56 is very hard to come by, and expensive, and the viper setup is worse, but easier to attain and can be bought as a whole kit.
Old 01-30-2006, 09:14 AM   #14
Bane-'s Avatar
Re: T-56 for fox?
I belive you can use/modify the chevy crossmember, seen it included with a ford kit somewhere...
« 1995 GT | Hey »
94 v6 - VS - Fox 5.0 sledgehammer Pre-2005 V6 Mustang 1 03-04-2008 04:44 PM
Someone with a fox.... fast64 Mustang Wheels & Tires 1 12-26-2007 08:00 PM
Termy vs. Fox bullitt482 The Bar 37 08-01-2007 05:12 PM
Might be getting another fox soon.. MonteCitan The Bar 29 04-14-2005 09:19 PM
What ya think of this Fox? lowflyn The Bar 29 01-22-2005 09:50 PM
11:27 PM
