AOD Questions - Mustang Evolution
Old 02-01-2006, 12:05 AM   #1
AOD Questions
Ok I have a little problem I need to know what stall converter to be used with the following combo in a 1990 Notch. 306 block, Ecam, ported cobra heads, Ported Cobra Intake, 3.73 gears. ANd anyone thats has installed the Wide gear ratio kit from ford racing is it worth it or not?
Matt
GizmosMustang is offline   Reply With Quote
Old 02-01-2006, 07:39 AM   #2
Re: AOD Questions
what are you wanting to do with the car, track, daily driver, etc etc?
Old 02-01-2006, 11:49 PM   #3
Re: AOD Questions
mostly daily driver but occasional drag.
Matt
It's never fun out running the cops! It's just fun to park in a dark Alley and watch them go by 5 times
Old 02-02-2006, 08:48 AM   #4
Re: AOD Questions
ive heard when people pick tq converters for their v6s they have to get a bit higher stall to get the same effects. Come on someone chime in that knows about tq converters!
Old 02-03-2006, 06:50 PM   #5
Tbird232ci's Avatar
Re: AOD Questions
torque converters and gears do very different things
do you have anything done to the driveline? Rear gears? Torque converter?
The wide ratio gears probably wont help you too much, but sticking a 3.73 rear gear in the car, and maybe something like a 2600-2800 stall torque converter in the car will wake it up considerably. Just be sure to run a GOOD transmission cooler, and a GOOD shift kit, such as a Trans-Go.
Old 02-09-2006, 10:18 AM   #6
Re: AOD Questions
sorry for the delay in post but this is what the car has stock converter AOD trans with B&M shift kit 3.73 gears the motor is in the shop being worked on trying to get it up to around 300 hp and 300 torque without a power adder.
90gt aod help Xx_1990GT_xX 1979-1995 Mustang GT 10 08-30-2008 10:50 AM
anyone looking for Th TV cable bushing for the AOD? Xx_1990GT_xX 1979-1995 Mustang GT 0 08-25-2008 09:37 AM
89 AOD question bob2231 1979-1995 Mustang GT 0 04-12-2008 08:12 PM
AOD tranny question? mustang slizzy 1979-1995 Mustang GT 3 12-09-2007 09:00 PM
aod on a 289 STEVE Pre-2005 V6 Mustang 8 05-11-2005 10:31 PM
08:48 AM
