pony won't gallop - Mustang Evolution
Old 02-02-2006, 10:53 AM   #1
pony won't gallop
I've just rebuilt my 89 GT, it's new from front to back minus a few sensors.
I have fuel at the rail getting to the injectors and good spark at the plugs. the vehicle turns over fine but will not start. The injectors are new but will not spray. I've checked wiring and all grounds and connections seem to be okay. just thought someone might have experienced this same problem
jjjeb is offline   Reply With Quote
Old 02-02-2006, 11:39 AM   #2
fast64's Avatar
Re: pony won't gallop
have you checked the fuel pressure?
GO BRAVES
Old 02-04-2006, 06:51 PM   #3
MonteCitan's Avatar
Check your fuel pump, have the door open, lean out a bit, and hit the key on, if you hear a whine/whir from the back of the car, you're set there and need to move on to check other things..
If you don't, check the fusible link D, the fuel pump relay, and the inertia switch, an ohmmeter is your best friend on this one, use a paperclip for the inertia switch (if it's set, and you have power to it -) as for the relay, try swapping with a good known relay (IE a new one or one that works on another circuit..)
If your fuel pump comes on, check the red wires to each injector for voltage, it should have voltage available any time the key is on, the circuit is closed by the PCM..
Is the PCM properly connected?
That's where I would start..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
My '09 Pony mrperple Pictures and Videos 9 08-06-2010 07:13 AM
My 4.6 pony needs SERIOUS help! VadenKwinn 1996-2004 Mustang GT 17 05-25-2010 10:42 AM
Got a New Pony! BlueSnake1013 Regional Mustang Discussion 16 01-18-2008 02:49 PM
Need a Running Pony lowflyn Mustang Audio & Video 11 08-23-2004 11:33 AM
09:15 PM
