just got an 89 5.0 lx - Mustang Evolution
Old 03-17-2006, 02:08 PM   #1
looking to make it faster but have a "wife budget" what are some things that are cheap i can do to make it faster, and btw, i am not to mechanical.
thanks,
sac
jersac is offline   Reply With Quote
Old 03-17-2006, 02:17 PM   #2
Re: just got an 89 5.0 lx
exhaust, cai, pulleys, gears, and other such things to start with. Im betting it already has exhasut simply because..... ( am i wrong?)
Old 03-17-2006, 02:21 PM   #3
the exhaust is dual "x'd", i have been told if i get it "h'd" it wouold increase horse power?
i also notice a significant difference when the thermastat is in or out, is there a particular thermastat i can put in that won't slow it down? or should i just run it without the thermastat?
Old 03-17-2006, 03:47 PM   #4
Its personal preference I wouldnt change the X to an H pipe on the exhaust, just leave it as is for now.
I am not understanding taking the thermostat in and out? its not just super easy to remove can you be more clear as to what you are talking about.
Old 03-17-2006, 05:48 PM   #5
Tbird232ci's Avatar
A thermostat makes no power difference no matter what you do. Just put a new one in and call it done.
Old 03-17-2006, 07:22 PM   #6
MonteCitan's Avatar
don't run without a tstat.. 1) the blockage in the system has a cooling effect (think like the fixed orifice in your AC system) and 2) if a car runs cooler than 160* cylinder wall wear is something like 5-10x what it is at optimum operating temperature when the entire engine is expanded and running as designed..
as far as modifications..
with 3.73 gears, a short throw shifter, CAI and exhaust (seems you already have exhaust) I ran high 13s with my 5.0..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-29-2006, 03:39 PM   #7
damighty5.0's Avatar
Bump your timing a little to 12*or13*.Use good plugs and wires. Ford racing 9mm wires. Good cap & rotor,and ignition coil.This is pretty basic and cheap I think.
damighty5.0 is offline   Reply With Quote
05:43 PM
