Control arm bolts? - Mustang Evolution
Old 03-18-2006, 07:01 AM   #1
Tbird232ci's Avatar
Control arm bolts?
I know for a fact that the control arm bolts wont come out easily from my red bird, and ill need new ones for my Mustang K-member swap. Anyone know where replacements can be had?
Old 03-18-2006, 09:42 AM   #2
Bane-'s Avatar
Re: Control arm bolts?
my yard...
Old 03-19-2006, 07:33 AM   #3
Joel5.0's Avatar
You could check what Breeze Auto has available or http://www.boltdepot.com/. Hope this helps.
1986 Mustang GT w/T-Tops :angryfire
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66 Small Port Heads, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears, LS Overhaul, Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), New Valve Springs (FRPP, done), Subframe Connectors (MM), Caster/Camber Plates (MM), T-Top weatherstriping and rear braces bodywork :cussing:
Joel5.0 is offline   Reply With Quote
Front and rear control arm hardware specs SilentNoise 1979-1995 Mustang GT 2 10-13-2009 07:51 AM
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
upper/lower control arm install chipshot101 1996-2004 Mustang GT 4 07-27-2004 07:18 PM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 10:37 AM
» Members Mustangs
DD
87LX306
Name?
meno1994
Add your Mustang
04:50 AM
