how many horsepowers? - Mustang Evolution
Old 03-19-2006, 05:03 PM   #1
Tbird232ci's Avatar
Ive gots my 5.0 close to being together LOL
itll be a stock 5oh with these modz:
-a cold air from ebayz
-under drive pulleys from da bay
-intake spacer, 1/2 probably
-smog is gone, a/c is out, PEACE!
-long toob hedderz, 2.5" duel exhausts with ultraflowz
what do you think ill make wif these modzorz
Old 03-19-2006, 05:05 PM   #2
fast64's Avatar
Re: how many horsepowers?
i was reading some guys cardomain with the same mods and he made like 324.689456 HP with similar mods (plus some nawz). he was beating like everything at the track, even a turbo civic, lolz!
GO BRAVES
Old 03-19-2006, 05:06 PM   #3
Tbird232ci's Avatar
ohhh snap!
Old 03-19-2006, 08:23 PM   #4
bbunt302's Avatar
Hmm... I'll guess around 200-210 at the wheels with a manual. I could be way off, but if I remember my stuff correctly they put between 180-190 down stock. Those mods should be good for at least 20 horsepower. The long tubes will help quite a bit... so you may end up closer to 215-220.
Get it dyno'd so you can tell me how far off I am.
Scary stuff.
Old 03-20-2006, 11:01 AM   #5
MonteCitan's Avatar
depends on the 5.0 too.. roller? HO or not?
if its a roller HO in perfect running shape.. with a manual transmission.. expect 200ish to the wheels.. and around 240-250 tq to the wheels
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-20-2006, 01:24 PM   #6
Tbird232ci's Avatar
roller, HO
Its going to be a shame when a mildly modded 2.3L is still going to be faster than a mildly modded 5.0
Old 03-20-2006, 01:43 PM   #7
RGR
Send a message via AIM to RGR
most 5.0's (87-930 were capable of around 260 BHP with mods liek that and
a good tune. So you sould see around 225 RWHP if you get the timing advance
where it needs to be. I've read that 13* BTDC is best. MIne ran really well
with that and similar mods. My Bro has had many hot Stangs and with my setup
he and his wife thought it was VERY strong.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-20-2006, 01:53 PM   #8
Tbird232ci's Avatar
I figure itll be pretty peppy.
Ive had good experience running 14* BTDC in other 5.0's on 93 octane fuel.
The biggest impact will be the 1 5/8 equal length long tubes, off road X or H, depends on how i feel when i place the order, and the ultra flow mufflers.
Its a 133K engine, its in great shape, ran great when it was pulled, just dirty and needs a regasket, which im doing, along with the minor mods.
In addition to what i listed, ill probably be running a 70mm MAF from a 4.6L MN12, which is calibrated for 19# injectors, a 65mm throttle body and maybe....MAYBE some roller rockers, 1.6's. Ill have an adjustable FPR, and a large fuel pump, probably a 255lph high pressure, i have forced induction aspirations. While not mods, theyll help in the long run.
Im aiming for maybe 220 at the wheels, hopefully on a nice day itll do it.
Old 03-23-2006, 06:22 PM   #9
RGR
Thumbs up Re: how many horsepowers?
k:
Old 04-02-2006, 10:14 PM   #10
12second5.0's Avatar
Send a message via AIM to 12second5.0
I'd say around 220 rwhp
12second5.0 is offline   Reply With Quote
Old 04-03-2006, 06:23 AM   #11
Nite-Mare's Avatar
Oh noes!! What about da torque?
Nite-Mare is offline   Reply With Quote
Old 04-03-2006, 07:43 AM   #12
Take the most power v6 mustang ever and you will have more than that because the 5.0 is always faster than the v6 always it doesnt matter.
Old 04-03-2006, 08:07 AM   #13
Zim
You want to **** me?
Zim's Avatar
ill guess about 20lbs more torque than HP... those long tubes will help the torque quite a bit
I like toys
Old 04-03-2006, 09:35 AM   #14
bbunt302's Avatar
I'd say easily 270-280ish lb/ft torque, remember these things made 300 at the fly stock. Which really is all that matters, cause that's where the fun is anyway.
Scary stuff.
Old 04-03-2006, 11:58 AM   #15
Nite-Mare's Avatar
Yes sir!!!
Old 04-03-2006, 07:37 PM   #16
Tbird232ci's Avatar
Exactly.
07:49 PM
