Which suspension system? - Mustang Evolution
Old 03-27-2006, 12:43 PM   #1
hey guys time to upgrade the suspension on the stang. going to use a kit from eibach. im looking at either their drag launch or the pro kits. most of my driving will be on the street, with some apperances at the track. the drag kit would be my choice but with only making a few runs at the track im not sure. advice, input,??
Clay89lxcoupe is offline   Reply With Quote
Old 03-27-2006, 02:10 PM   #2
bbunt302's Avatar
Re: Which suspension system?
It just depends on whether or not you want to sacrifice handling ability on the street for quicker launches at the track. It's simply a matter of which is sounds better to you: 1) the car feeling like it's on rails but having some traction problems coming out of the hole... or 2) being able to squat and leave the line like a bat out of hell but having to take it somewhat easy in the curves.
I personally spend way more time on the street than I do at the track, so I chose to go with a stiffer suspension. That's just my personal preference though.
Also, I recommend you check out Maximum Motorsports, they are the best place to go for Mustang suspension parts, even though they most cost a little more than some other places. Their parts are top-notch.
Scary stuff.
Old 03-28-2006, 10:58 AM   #3
Bane-'s Avatar
Also is it your daily driver or not? My car will only see the track maybe a couple times a year and thats doubtful. I still went with a little stiffer suspension, since its not my daily driver.
Old 03-28-2006, 12:09 PM   #4
the car will be driven on the weekends. i have a truck for work during the week
Old 04-02-2006, 04:06 PM   #5
Zim
You want to **** me?
Zim's Avatar
Are you looking to do just springs or the whoel thing? With new springs, Id recommend new shocks/struts at the same time as the springs since your stock ones arent valved for the increased spring rates that either of those springs will give you. You'll also probably need to invest in some caster camber plates to get a correct alignment. For shocks/struts Id look at some tokico's if yorue on a budget, or some bilsteins if you want the best. With C/C plates I only recommend the max motorsports ones. Our sponsor, www.stangsuspension.com has them for 189.99 I believe... theyre a 4 bolt design and the best ones out there.
I like toys
Old 04-02-2006, 10:09 PM   #6
12second5.0's Avatar
Send a message via AIM to 12second5.0
I'd just leave the stock springs and go with new rear control arms along with new shocks and struts.
12second5.0 is offline   Reply With Quote
need opinions on new sound system for 98 cobra with Mach system tennisfreak802 Mustang Audio & Video 7 04-28-2010 01:29 PM
suspension bobbyoooo 1996-2004 Mustang GT 7 07-03-2009 03:08 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
some ? about suspension carlosc Pre-2005 V6 Mustang 6 12-08-2008 11:44 AM
Best Suspension Matt'sredbeauty Pre-2005 V6 Mustang 28 04-05-2005 05:15 AM
» Members Mustangs
STANG 1
stang1
STANG
MedMan
Add your Mustang
05:18 PM
