ok you guys give good info so heres go - Mustang Evolution
Old 02-24-2010, 02:36 PM   #1
i have a 95 gt i need my whole suspension done front and rear im only replacing parts that have to be for example im keeping front lower control arms but replacing ball joints and bushing but im wondering should i replace the whole anti roll portion of the suspension or keep the factory sway bar and just replace to links and bushing i know which ones cheaper but what would be the best way to go and one other thing struts which are best for my car gas operated mono and twin i have no idea please help
durtyred69 is offline   Reply With Quote
Old 02-24-2010, 02:38 PM   #2
Re: ok you guys give good info so heres go
I'm not a suspension guru, however, there is one question you need to answer before anyone can comment accurately. What is the purpose of your car? Drag strip? Auto cross? Road coarse? Street comfort?
Then, our suspension guru's can give you an accurate recipe of what to do to your car.
Old 02-24-2010, 02:45 PM   #3
well i dont plan on going to the track i guess the best answer for that would be strip
Old 02-24-2010, 02:49 PM   #4
well i do plan on going to the track so i would street rod i guess
Old 02-24-2010, 05:08 PM   #5
Zim
You want to **** me?
Zim's Avatar
It's up to you really...
Obviously different sway bars are going to help your body roll. A stiffer spring will also increase handling, and with the right spring will not disrupt your road comfort.
Personally, if it was me replacing my suspension and I generally drove it on the street with an occasional track outing, I'd make it look good, and count on sticky *** tires for my track endeavors rather than a suspension that will create the proper weight distribution for a solid launch. I'd lower it, match a solid spring with a shock/strut combo that's valved for the spring stiffness, and go from there.
I like toys
Old 02-25-2010, 07:16 AM   #6
it all depends on what you want to do, if its just a daily driver... there is no need to sink 10k in the suspension. If you drag race the car... no need to do certain things than an autox car would do... so it all depends on what you want out of the car.
Ive only done springs mostly for my car as I dont drag race it or autox~ I plan to do bushings but thats for wheel hop.
Old 02-25-2010, 08:31 AM   #7
I already asked him that, and he replied, kind of...
Old 02-25-2010, 11:06 AM   #8
i need some info about 95 stang
what are the basic things you need to check or have done before you start any upgrades to your 95 stang i have jump the gun already with msd distrubtor and bbk cold air intake i know timing is important and to check compression what else
Old 02-25-2010, 03:24 PM   #9
Zim
Zim's Avatar
I wouldnt say theres any basic things you need to check. Just make sure your car is in good running order and properly maintained. A distributor and cold air arent going to affect the way your car runs anymore than the stock components (for the most part). The things I would suggest is making sure you have clean fluids in the car (trans, brake, oil, coolant, rear diff, etc) as well as regular maintenance items looking to be in good order. Things like spark plugs, wires, belts, hoses, those sorts of things. The 302 is a pretty reliable motor, and unless its been absolutely ragged on, you shouldn't have much for compression problems. You can check it for peace of mind, but if compression was low in one or more cylinder, you'd probably know by the way it runs.
Just start modding... replace those old worn out parts with pretty, new, performance aftermarket parts.
I like toys
Looking for LED lights... u guys got info? Julio Salsa 2011-2014 Mustang GT 12 12-18-2010 07:49 AM
That's it! I ****in give up and just don't give a **** anymore SilentNoise The Bar 25 07-05-2009 04:02 PM
Good Info On late model Suspension Herbstang Pre-2005 V6 Mustang 0 08-07-2007 11:35 AM
An article I found on mileage, mostly good info RGR Pre-2005 V6 Mustang 19 11-29-2006 04:45 PM
Need some info from you guys!!!! Danger Dude Mustang Audio & Video 20 06-11-2005 11:18 AM
» Members Mustangs
TOYDOS
Toydos
Shelby
C013RA
Add your Mustang
05:43 AM
