a ? about my 95 stang plz help asap!!!! - Mustang Evolution
Old 02-25-2010, 11:15 AM   #1
what are the basic things that need to be done before you start upgrading and modify your engine i have already done a couple of upgrades like a msd distrubtor and bbk cold air intake i know two basic things that should be done or check is timing and compression what else should i do before going any further
next question being that i have a msd distrubtor and bbk cold airtake i really dont notice a difference in the car should i have it tuned since i have those parts on there or will tuning even make a difference at all with those simple upgrades plz help asap
durtyred69 is offline   Reply With Quote
Old 02-25-2010, 12:19 PM   #2
big show 98's Avatar
Re: a ? about my 95 stang plz help asap!!!!
Have you advanced your timing?
big show 98 is offline   Reply With Quote
Old 02-25-2010, 03:25 PM   #3
no is that something i have to do since i have the msd and cold air intake
Old 02-25-2010, 05:00 PM   #4
Usually one of the first mods to do on a 5.0. You can go between 12-14 degrees on the timing, it depends on the octane you want to run in your car. I always kept mine @ 14 degrees. There is a computer module located where the factory airbox mounts. It's a little gray plug that has to be removed in order for the car to except the timing advance. Do you have an o/r mid pipe? If not it will help out alot also.
Old 02-26-2010, 08:25 AM   #5
lugthug713's Avatar
Gears. 5 sp go with 3.73 or auto go with 4.10 gears. Then get a intake manifold like gt40 or trickflow there are others but that a good start. Underdrive pullys. O ya if you get a intake manifold jsut hold off on switching it out untill you can find some heads to put on all at the same time. GT40 heads off explorer with be the cheapest way and still get good power
lugthug713 is offline   Reply With Quote
need some help plz. j4gwig General Mustang Discussion 2 05-10-2010 05:29 PM
plz welcome me Qatari Mustang New Member Introductions & Greetings 10 09-24-2009 09:20 AM
estimate plz upton7 General Mustang Discussion 4 04-03-2009 02:36 PM
I need help!!! PLZ!! Khstang Pre-2005 V6 Mustang 18 04-21-2008 10:33 PM
Need some help plz! graveelement Pre-2005 V6 Mustang 0 02-09-2008 03:15 PM
06:00 PM
