need help - Mustang Evolution
Old 04-14-2006, 10:45 AM   #1
need help
our '91 5.0 LX w/AOD is having some problems and I could use your help. When i am decellerating a low speeds, like slowing to stop at a light or to make a turn I can hear(and kinda feel) a clunking noise. It sounds like it may be coming from the front of the tranny, TC maybe? But as soon as you push the gas a little or slow down more it quits. It doesn't do it in neutral, only when in gear and slowing down or atleast off the gas. When it first started this it wasn't as bad as it is now.
MustangBrandy is offline   Reply With Quote
Old 04-18-2006, 05:45 PM   #2
thexrcist68's Avatar
Re: need help
maybe U-Joints?
We cant stop here, this is bat country.
1986 Mercury Capri, 5.0 3.73s t-4:mad: (buildup in progress)
1968 Mercury Cougar XR-7 (Cruiser) 302, C4, some mods
01 Dodge 1500 (DD)
thexrcist68 is offline   Reply With Quote
Old 04-19-2006, 08:04 AM   #3
Re: need help
sounds like U joints or something in the drivetrain~ I would check the U joints and make sure the driveshaft is tight where its bolted to rear as well (im sure it is but should be checked cuz you never know)
Old 04-19-2006, 08:58 AM   #4
Re: need help
doesn't really sound like u-joints to me but I'll check anyway, it's all kinda hard to explain, would be better if you could hear it for yourself
Old 04-19-2006, 06:09 PM   #5
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: need help
Sounds like you are describing the torque converter is staying engaged in lockup.
12second5.0 is offline   Reply With Quote
Old 04-24-2006, 08:55 AM   #6
Re: need help
well I think the problem may be fixed. We installed our new offroad x-pipe this weekend and while we had it up on the lift we noticed that one of the mufflers was rubbing against the driveshaft 2: so after we'd finished with the x-pipe it shifted everything a little and now it's not rubbing. I didn't think something like that would have made that kind of noise but we haven't heard it anymore since then...hopefully it's fixed:thumbs2:
Old 04-27-2006, 08:28 PM   #7
Re: need help
You may want to check the tranny mount also. I had a similar problem on a 92 conv. t-5
DanzCherry68 is offline   Reply With Quote
01:59 PM
