Ive been inspired, Im gonna fab up my own S/C - Page 2 - Mustang Evolution
Old 04-18-2006, 08:35 AM   #36
Re: Ive been inspired, Im gonna fab up my own S/C
Originally Posted by SpectorV
just admit it you want a modular motor.
Hmm...think I would rather the 5.0 with the eaton/kb/whipple than the modular.
Old 04-18-2006, 10:22 AM   #37
Old 04-18-2006, 10:23 AM   #38
Mustangs from 94 to 98 with the 96-98 style rear tail lights run 10-15 degrees cooler. Yet another reason to upgrade, other than the fact that 96-98 look so much better in every way always ever.
Old 04-18-2006, 03:28 PM   #39
Dom
Dom's Avatar
Send a message via AIM to Dom
Cause those tail lights, hood, and stock spoiler made such a difference.
Zim's car looks meaner. Plus, it came with the V6 bumper.
Old 04-18-2006, 05:24 PM   #40
Hey Zim....here are some numbers for you:
across the back from edge to the outside part of the plenum is 12"
across the back from edge to the outside part of the throttle body is 13"
across the back from edge to the outside part of the intake tube is 17"
Front to back is 23"
Actual width is 8"
Height from the top of the lower intake is 6"
From the top of the lower to the bottom of the pulley I didn't measure, but, I have a 2.76" pulley, so subtract about 1.38" from the previous measurment...so we are looking at around 4.75"...but that is with my 15 lb pulley. the pulley you would run would be a 3.5" pulley, so...that would be about 4.25"
Let me know if you need any different numbers....or anything.
Old 04-18-2006, 07:46 PM   #41
DarkShadow's Avatar
Send a message via AIM to DarkShadow
You could just run a huge air to air intercooler and not have to worry about the fluid box location...
You will see much higher intake temps unless you declare war on them and go all out to keep them down, by this you would need an additional tranny cooler, oil cooler, ceramic coating, heat wrapping, what is it..methanol or nitrous sprayed IC? You will have high temps unless you do a lot to keep them down. I'm realizing this. I need to do something about my tranny...I just have the B&M hiTeck hooked up now, but I need to piggyback that and my stock cooler.
DarkShadow is offline   Reply With Quote
Old 04-20-2006, 08:45 PM   #42
Fishers Stang's Avatar
thats cool ZIM, good luck. here is a pic I had from a car show a while back
Charles
Old 04-21-2006, 09:14 AM   #43
Zim
You want to **** me?
Zim's Avatar
mmm kenne bell
I like toys
Old 04-27-2006, 07:39 PM   #44
I have two blower car one roots and one vortech. I highly suggest the water cooled. This is a little extreme, but here is a good link to someone running a custom intercooler lots of good info. I have the same setup as his on my Q.
http://www.superstang.com/
DanzCherry68 is offline   Reply With Quote
Old 05-01-2006, 04:15 PM   #45
Region: Arkansas
Why not just put a turbo on it or two. I have seen several on the 5.0's and I am thinking of throwing one on mine, in the future. I mean its all fine and dandy to put a m112 on it but why? If your hell bent on this setup I wish you luck and hope you get it worked out.
Zak Attack is offline   Reply With Quote
Old 05-01-2006, 08:16 PM   #46
Zim
Zim's Avatar
yeah i dont think its happeneing... started saving for a centrif. blower and should get it sometime in june or july... so Im going the other way.
I like toys
Old 05-01-2006, 08:23 PM   #47
12second5.0's Avatar
Send a message via AIM to 12second5.0
Good idea.........I never regret the purchase of my SQ trim.
12second5.0 is offline   Reply With Quote
Old 05-01-2006, 09:03 PM   #48
Zim
Zim's Avatar
Yeah, Im gonna start with an entry level blower and go with the powerdyne. Its self contained, and looks to be an easy install. Plus running only 6-8lbs, my 24 # injectors should be ok on a conservative tune. I found a guy on corral upgrading to a turbo setup, so when does that he's gonna sell me a rebuilt head unit along with everything else I need. Its possible that he might even throw in 42lb injectors and a MAF calibrated for them. Should be fun this summer
I like toys
Old 05-01-2006, 09:55 PM   #49
Why settle for a Powwerdyne?All you will ever see is 6-7 lbs of boost max.The install was a piece of cake on my Vortech and I have zero oil leaks.You are giving up an extra 100 rwhp with that blower vs. a Vortech,Novi,or even Procharger
Old 05-01-2006, 10:07 PM   #50
Zim
Zim's Avatar
Thats ok, its in my price range and itll work well for what I want to use it for. Im not looking for a track monster... I basically want a nicely tuned street car with occasional track visits. Also, depending on whether the guy includes the bigger maf and 42# injectors, I could pulley it differently and get a little more boost out of it.
I like toys
Old 05-01-2006, 10:13 PM   #51
That's the trouble with the powerdyne.Try to pulley it different and get more boost then you will break the internal blower belt. Mine is not a track car either. I was looking for just a nice sleeper car.
Old 05-01-2006, 10:19 PM   #52
Zim
Zim's Avatar
If i can get a consistant 9psi out of the powerdyne, ill be perfectly happy with that. This is just an entry level blower for me... I dont want too much power to the point where I have to worry about blowing other stuff up such as my weak tranny lol. For now itll be fine until I get out of school, and get a job to fund my hobby. It wont be a monster, but ill have some decent power... and thats basically what Im looking for.
I like toys
Old 05-01-2006, 10:23 PM   #53
You'll be doing good to get 7 out of it.
Old 05-01-2006, 10:25 PM   #54
Zim
Zim's Avatar
well hopefully my combo just ends up being one of those that just works together nicely. I also want to have my upper and lower intakes ported sometime eventually. Know of any good porting companies that do good work on the gt40s?
I like toys
Old 05-01-2006, 10:33 PM   #55
Zim
Zim's Avatar
I saw this from another board... this guy's running the BD11A also
Engine
Block
302 High Output Stock Short Block
Cylinder Heads
GT-40P Ported with Tornado Crane Springs
Intake Manifold
Holley Systemax Stage 2 Ported and Polished
Camshaft
E303 Ford Cam
Roller Rockers
1.6 Scorpions
Pulleys
ASP Underdrives With Custom One piece Supercharger and Crank pulley
Power Adder
Powerdyne BD-11A with a 8-Rib Pulley pushout 9.5 PSI
Exhaust
BBK shorties, BBK High Flow H-Pipe, 2.5" Exhaust, 40 Series Flowmasters
Fuel
Throttle Body
75mm BBK
Mass Air Flow
90mm Lighning MAF with K&N FIPK
Induction
Custom Ram Air into UPR Powerpipe
Fuel Injectors
42lb/hr
Fuel Pump
255LHP Forced Induction
FMU
Powerdyne with Stainless Fuel Lines Return Lines
Fuel Pressure Reg.
Aeromotive Adj.
Basically the only thing different from my car is the intake he has, and I have 1.7 rockers. He made 443/446 to the wheels :dunno:
I like toys
Old 05-01-2006, 10:43 PM   #56
I'd say he's one of the lucky ones to get that much boost from one. If it makes you happy going with the Powerdyne then by all means go for it.They have alot going for them as far as easy install and to add the are inexpensive.
Old 05-01-2006, 10:48 PM   #57
Zim
Zim's Avatar
I think whats helping him is he has that UPR powerpipe on it... Arent those usually good for a couple psi?
I like toys
Old 05-01-2006, 10:50 PM   #58
They advertise 2-3 psi.I didn't see a difference in mine.I just wanted the cleaner look then that crap vortech gives you.
1965 Fiber-Fab front clip sheila sells New Member Introductions & Greetings 0 01-23-2010 11:18 AM
i have been inspired to build this certain type of catapult Cajun JungleBoy Pictures and Videos 10 03-15-2007 12:06 PM
Pretty neat fab forum rocknbronco The Bar 6 12-20-2006 01:39 PM
Disaster Film, Many Beers Inspired Fire, Man Says .:DarkEntity:. The Bar 6 10-18-2004 12:55 PM
05:22 PM
