Tranny/Shifter problem... - Mustang Evolution
Old 04-20-2006, 04:15 PM   #1
Fast93Coupe's Avatar
Question Tranny/Shifter problem...
I just installed a B&M Ripper Shifter, and I love it. Until I hit second or fourth!
It was doing it before, with the stock shifter. The stick hits the center console and I cant get it in second or fourth gear with out holding it. Its like my tranny needs to be closer to the front. According to buddies 5.0 it does, but why? So im driving around with the boot and cover off my shifter. Any help would be appreciated. It has been wrecked...But you wouldnt even know it.
Fast93Coupe is offline   Reply With Quote
Old 04-20-2006, 05:22 PM   #2
MonteCitan's Avatar
Re: Tranny/Shifter problem...
how bad was it wrecked? Got a pic of the area where the shifter is? how is the trans mount? my 89 wouldn't go into second or 4th after snapping one side of my trans mount launching at 4k RPMs on ET streets
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-21-2006, 03:25 AM   #3
Kiljosh's Avatar
Your sure you just dont have the stops adjusted wrong?
Old 04-22-2006, 06:43 AM   #4
Could be...But the stock shifter was doing the same thing. D@&n I wish I knew what the problem was! Thanks so far.
Old 04-22-2006, 07:32 AM   #5
Tbird232ci's Avatar
Possibility of it having a 94+ transmission in it?
Old 04-22-2006, 02:00 PM   #6
How different are the 94-95 Trannys from the fox bodies? I'm not sure if thats what it is, but its a possibility...
Old 04-22-2006, 03:26 PM   #7
Tbird232ci's Avatar
the bellhousing is anywhere from 5/8's to 3/4 of an inch longer than the fox bodies, and the input shaft is longer also, meaning that the shifter would be moved back about 3/4 of an inch using one of those transmissions. If the car is wrecked, it could have been replaced, along with the car being slightly "shorter" than it was before.
tranny problem ? 1 dark demon 2005-2010 Mustang GT 21 10-31-2008 02:03 PM
Tranny Problem? i think... DMAC Pre-2005 V6 Mustang 2 05-16-2007 03:08 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
tranny problem? 232SCstang Pre-2005 V6 Mustang 3 03-15-2004 01:15 PM
Tranny Problem.... v6mustangguy Pre-2005 V6 Mustang 16 01-31-2004 06:11 PM
03:51 AM
