Engine just stops - Mustang Evolution
Old 04-21-2006, 06:54 AM   #1
scorpionSStang's Avatar
Engine just stops
while the car is running and reaches normal operating temerature the engine just dies. if u try to start it back it wil just crank over, will not hit or anything. wait about 10 minutes it will start back until it reaches its normal temp.....any ideas?
scorpionSStang is offline   Reply With Quote
Old 04-21-2006, 10:49 PM   #2
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: Engine just stops
Any other symptoms? Running through coolant? Smoke from the exhaust?
Old 04-22-2006, 12:42 AM   #3
Kiljosh's Avatar
That sounds like a problem with your thermostat
Old 04-22-2006, 12:50 AM   #4
I have never heard of a thermostat shutting a car down?? Though I dont know what else it could be.
Old 04-22-2006, 04:57 AM   #5
no i dont have a coolant problem...i remeber those front wheel drive chevy cars like berettas cavaliers..etc with those 2.8 and 3.1 multi ports. they had crank position sensors and the magnets on the end of them would crack and when the car reached normal temperature the magnet would expand causing the coil not to fire..let it sit for 10 minutes it would run again...im pretty sure the 5.0 doesnt have these but im not positive
Old 04-22-2006, 05:58 AM   #6
MonteCitan's Avatar
doesn't stumble or buck at all? just shuts down? Replaced your TFI module lately?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-22-2006, 08:34 AM   #7
Tbird232ci's Avatar
Thats what i was thinking.
Old 04-23-2006, 02:26 AM   #8
doesnt stumble any acts just like you turned they key off. that is an idea replacing the tfi module. i got a paper once saying they recalled them on my particular model but i couldnt get it done for free since i was the 2nd owner of the car. thanks for your reply and all replies to my problem -tom
Old 04-23-2006, 07:07 AM   #9
MonteCitan's Avatar
I would definitely start with the TFI module then, I doubt its an ignition switch problem as that wouldn't be affected by engine temperature, and it would happen more frequently, plus car wouldn't typically crank over again immediately
At the moment its the only thing I could think of that would cause it to just cut out like turning the key off, and it would cause the coil to lose its driver signal..
Old 04-23-2006, 10:02 AM   #10
Tbird232ci's Avatar
check codes.
Old 04-27-2006, 09:29 PM   #11
Fuel filter?
DanzCherry68 is offline   Reply With Quote
Which engine to use :-) Babydoll Pre-2005 V6 Mustang 26 07-22-2009 08:12 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 08:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 03:01 PM
New Engine!!!! drummerstang98 The Bar 18 01-02-2005 05:38 PM
12:35 AM
