which cam - Mustang Evolution
Old 04-22-2006, 05:54 AM   #1
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
which cam
I wanna put a cam in my 5.0 but i dont know which one or where to get one from... if u guys could help me out..thanks
Justin is offline   Reply With Quote
Old 04-22-2006, 07:33 AM   #2
Tbird232ci's Avatar
Re: which cam
Whats done to your car?
A camshaft isnt a bolt on really, its an integral part of your setup.
Give me this informantion:
-year
-transmission
-modifications
-ultimate goal
-planned mods
Old 04-23-2006, 03:59 PM   #3
Justin's Avatar
Re: which cam
1995 5.0
Stock Tranny
only mod is exhaust (eventually i will mod more)
for right now i want a loopy idle (just like the way the idle sounds)
planned mods are headers, gears, diffrent tranny
Old 04-23-2006, 07:36 PM   #4
Zim
You want to **** me?
Zim's Avatar
Re: which cam
For a milder cam, lots of people go with the e303 or crane 2031... Ive got the e303 and it makes that sweet lope idle
I like toys
Old 04-23-2006, 09:04 PM   #5
Re: which cam
Originally Posted by EboniteStr1ker
1995 5.0
Stock Tranny
Is the stock tranny an auto or 5speed
Old 04-23-2006, 10:32 PM   #6
Justin's Avatar
Re: which cam
i have auto.....also is there anyway you could post a sound or video clip of the idle please...im newbi at all this....i just got a job that pays good and i can finally start doing mods to my car...thanks guys for all the help..this is the most helpful site out there...by far the best
Old 04-23-2006, 11:21 PM   #7
bbunt302's Avatar
Re: which cam
Honestly... you'll make more power with a cam that doesn't lope on a stock motor.
The E cam and the Crane Powermax 2031 are actually the same cam. They are also intended more for slightly higher revving and better flowing setups than stock. Here's Crane's description of the cam:
"GOOD MID-RANGE AND STRONG TOP-END POWER, REQUIRES MODIFIED MASS AIRFLOW, AFTERMARKET INTAKE, PERF. CYLINDER HEADS AND HEADERS, MUST USE 5-SPD AND 3.55 OR NUMERICALLY HIGHER REAR GEARS."
A lot of people use it in near stock applications because it "sounds good". If you don't mind losing a little bit of power (mostly low-end torque) for the sound then it'll be fine. It will definitely sound good (110* LSA = lope).
If you'd rather have a cam that may make a little more power than the stock cam and work well with the stock parts... check out the smaller cams in Comp Cams Xtreme Energy line, particularly the XE258HR and XE264HR.
In reality though, the stock cam is actually a decent cam for the stock heads and intake. Really, the only reason to swap out a 5.0 HO cam on an otherwise stock motor (meaning stock heads and intake), is to make it sound good. You make pick up a few hp with one of the XE cams or something similar... but it probably isn't worth the work and money. So if you just want the sound, the E303 isn't a bad choice. Just be warned that you may lose a little bit of bottom end in exchange.
Scary stuff.
Old 04-24-2006, 12:35 PM   #8
Zim
Zim's Avatar
Re: which cam
There should be a couple clips in my gallery if you go to the top right of the screen and click photo gallery, then find my name in there.
I like toys
Old 04-24-2006, 05:27 PM   #9
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: which cam
Throwing a cam in your car at this time is a waste of money.I'd wait until you plan on some heads and intake upgrades.
12second5.0 is offline   Reply With Quote
Old 04-24-2006, 08:58 PM   #10
Re: which cam
I forgot to tell you you will need new headgaskets and head bolts, Timing Cover gasket and intake gaskets.
Old 04-25-2006, 04:06 PM   #11
Tbird232ci's Avatar
Re: which cam
Why would you need headgaskets and bolts?
Old 04-25-2006, 04:15 PM   #12
Re: which cam
NM, I don't know what I was thinking lol
Which Cam? b's stang 2005-2010 Mustang GT 2 07-18-2010 10:25 PM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
cam and rr? cjd10 Pre-2005 V6 Mustang 16 02-08-2005 04:12 PM
04:27 AM
