Which Mods - Mustang Evolution
Old 04-25-2006, 07:00 PM   #1
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Which Mods
I have a 95 gt...auto...i was wondering what mods should i do first that are fairly cheap...i only make 550 and 30 - 40 hours a week...so which mods should i do first...i decided to wait in the cam that i was askin about so any suggestions whould be great..thanks
Justin is offline   Reply With Quote
Old 04-25-2006, 07:08 PM   #2
Re: Which Mods
Shift Kit for your Automatic
Exhaust. Either Catted X Pipe or Off Road X Pipe... your choice of a catback
Rear End Gears are a poor mans supercharger. Throw some 4.10 gears in your rear and watch your car come ALIVE.
With 180,000 miles on your car I would change spark plugs, spark plug wires, fuel filter, transmission fluid.. just general maintenace stuff before getting too mod happy. If you have already done this then good.
Old 04-25-2006, 07:13 PM   #3
Justin's Avatar
Re: Which Mods
already done the genral stuff...have shift kit..thanks for the suggestions
Old 04-25-2006, 07:33 PM   #4
Re: Which Mods
Is it a valve body shift kit or one of those electrical ones
Old 04-25-2006, 08:04 PM   #5
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: Which Mods
Gears,exhaust and intake
12second5.0 is offline   Reply With Quote
Old 04-25-2006, 08:18 PM   #6
Zim
You want to **** me?
Zim's Avatar
Re: Which Mods
eBay Motors: GT40 GT 40 Intake manifold upper, lower & spacer (item 8059208475 end time Apr-29-06 10:03:50 PDT)
that right there will give you close to 30hp and nice torque
I like toys
Old 04-25-2006, 09:19 PM   #7
Justin's Avatar
Re: Which Mods
valve body
Old 04-25-2006, 09:28 PM   #8
Re: Which Mods
valve body
Ok good
Old 04-26-2006, 08:08 AM   #9
Re: Which Mods
I would start by making sure what you have is running top notch, a good tune up if you will. Then start the moding. I would change all the fluids in the car (all of them including power steering etc) and the plug wires every 60k and plugs every 30k~ etc etc.
Exhaust, gears, intakes, induction (CAI), pulleys, etc etc its a long list
Old 04-26-2006, 10:05 PM   #10
KFP
Send a message via AIM to KFP
Re: Which Mods
I've been informed on a three mod rule when it comes to quick power. Cam, gears, and intake. A decent intake can run $150-$300. Gears obviously is the quickest way to make your car get up to speed faster. Cam is probably the biggest thing to mod, pick a more aggressive cam. When you go with intake I suggest an edlebrok victor jr. with the air gap. The air gap is more for your RPM range.
KFP is offline   Reply With Quote
Old 04-26-2006, 11:41 PM   #11
Re: Which Mods
Heads are a good addition to a cam. Too wild of a cam on a low flowing head will not give you very good results for just a cam. So I have been told atleast
Old 04-27-2006, 07:28 AM   #12
Re: Which Mods
You are correct.Sometimes the results could be worse than stock........
Old 04-27-2006, 11:28 AM   #13
bbunt302's Avatar
Re: Which Mods
I would change that rule for a 5.0L and say gears, exhaust, intake, with the intake being last. A cam is really not worth the money and install effort (IMHO) on a 5.0L with the stock heads. The stock 5.0L cam is actually a pretty good match to the stock heads.
First and foremost, I'd do a good tune-up. Spark plugs, wires, fuel filter, distributor rotor and cap, change coolant & tranny fluid, and so forth. All the mods in the world will be useless if the car isn't in good running condition.
For the gears, the norm seems to be 4.10s for an auto, unless you do a lot of highway driving in which case 3.73s might be better.
For exhaust, just pick whichever catback you think sounds best and match it up with either a H-pipe or X-pipe. If you can get away without cats, I'd recommend a Mac ProChamber which is a sort of cross between a H and X pipe. Headers will help a little, but the stock headers aren't bad. So if you're on a tight budget they may not be worth it.
For an intake, since you're going to be running stock heads/cam, I'd recommend either the FRPP Cobra intake or the Edelbrock Performer. The Trick Flow Street Heat isn't too bad either.
There are also a lot of little things you can do like underdrive pullies (I'd recommend to only use the crank pulley but that's just me), bump the timing a little (may need to run higher octane fuel), CAI, alternator upgrade w/ electric fan, etc. Of course, all these little things can quickly add up as far as cost goes.
There's really a lot of things you can do for more power, it's just a matter of how much you're willing to spend and how far you want to take it.
Scary stuff.
Old 04-27-2006, 12:48 PM   #14
Justin's Avatar
Re: Which Mods
got flowmasters and turn downs put on today...gonna run it out the rear next.... its not as loud as i want it so is there any suggestion on some tips that would help make it a lil louder and what would yall suggest that i do next?
Old 04-27-2006, 12:58 PM   #15
Re: Which Mods
Taking the cats off will def make it louder. I like the way a catless 5.0 sounds.
Old 04-27-2006, 01:20 PM   #16
Justin's Avatar
Re: Which Mods
i only have the two elbow ones on there...i was thinkin some bigger longer tips....also when we were doin my mufflers...we found that i have aftermarket headers on there...so i have Shift Kit, Headers, K & N Filter, and flowmasters now
Old 04-27-2006, 01:23 PM   #17
bbunt302's Avatar
Re: Which Mods
Turn downs are louder than any tip you can put on there. Even if you already had tips though, going to a bigger tip won't really make it even louder. It'll just give it a deeper sound.
If you want it to be louder, get rid of the cats with a offroad H or X pipe (or the ProChamber I recommended above).
Scary stuff.
Old 04-27-2006, 01:31 PM   #18
Justin's Avatar
Re: Which Mods
when i go back to get this done the dude is gonna be like WTF arnt you ever pleased.... and im out of money for now...im guessin it will cost about $50 to cut them and make a new pipe
Old 04-27-2006, 03:34 PM   #19
Zim
Zim's Avatar
Re: Which Mods
how loud do you want it?? If you get some long tubes, and an o/r H itll be quite a bit louder. Mines uber loud with the cam, headers, midpipe, and mac catback
I like toys
Old 04-27-2006, 03:53 PM   #20
Tbird232ci's Avatar
Re: Which Mods
Didnt you know, loud=fast
Old 04-27-2006, 05:43 PM   #21
bullitt482's Avatar
Re: Which Mods
Yeah the Bullitt is loud w/o headers. The 91 is loud also. The only reason it has a b-cam though is bc it was in there when we got it. Sounds DAM good though with the equallength shorties, offroad x, and 40 series dumps.
bumbubmbumbumb.
Couldn't imagine how loud this guy wants his car though...
Some welcome mods... The Whistler Pictures and Videos 10 03-23-2011 12:24 PM
mods going on lightning 1996-2004 Mustang GT 4 03-23-2011 12:18 PM
New Mods... The Whistler Pictures and Videos 12 10-10-2008 11:24 AM
What mods? 00 V6 smith710 Pre-2005 V6 Mustang 15 05-01-2008 11:03 AM
all mods are done...........almost Kyle Pictures and Videos 26 04-24-2007 02:52 PM
07:49 AM
