1987 GT altenator will not charge??? PLEASE HELP!!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 03-17-2010, 12:27 PM   #1
ERIC1987GT is unknown around these parts
Hi everyone, I just bought my dream car!!! 1987 Ford Mustang GT with only 80k on it. The car is amazing has a ton of work which I will get into but for right now I need to fix this problem..The battery died, I put a new batt in her, then I found out that its running only on the batt, I put a new altenator in it and its just not holding a charge and now my new batt is on its way out after 50miles.. I dont know what to do..PLease help...
Thanks
Eric
ERIC1987GT is offline
Old 03-17-2010, 02:45 PM   #2
SaleenFiend's Avatar
SaleenFiend is unknown around these parts
Re: 1987 GT altenator will not charge??? PLEASE HELP!!!
Battery should be warranty. Have someone check the volts with a meter when under a load or not. Also check all wiring to/from alternator for frays, damage, or disconnection.
SaleenFiend is offline
Old 03-17-2010, 02:59 PM   #3
Terminator Owner
SpectorV is just getting started.
if the alternator is spinning and its new and the battery is good.. then it can only be the linkage from the alternator to the battery unless the alternator is messed up or the battery is~ but a auto store can test them and ensure they are right. Make sure the belt is right and tight as well.
SpectorV is offline
Old 03-17-2010, 06:29 PM   #4
big show 98's Avatar
big show 98 is unknown around these parts
The new alternator should have come with a new plug for it. If it didn't you need to go & buy one & replace it. They go bad on these cars.
1998 coupe auto 3.27
2.25 h-pipe 2 cats
2.25 gt cat back
Mac UDP
K&N drop in
big show 98 is offline
Old 03-18-2010, 09:06 AM   #5
hottcobra's Avatar
hottcobra is unknown around these parts
Voltage is supplied to the alt with one of the small wires when you turn the key on of the alt doesn't get the voltage to tell it to turn on it won't charge.
hottcobra is offline
Closed Thread
TURBO CHARGE or SUPERCHARGE usmc_berkeley 2010-2014 Mustang GT 10 12-23-2009 02:11 PM
Starter..Altenator..or both? MuStAnGcHIk88 Pre-2005 V6 Mustang 5 12-03-2007 08:36 PM
Looking to charge my car? BloodyMustang 1996-2004 Mustang GT 15 07-11-2007 06:21 AM
CHARGE !!! HELP!! ATFPat 1979-1995 Mustang GT 8 04-11-2007 03:32 PM
ALT charge TBone Pre-2005 V6 Mustang 12 07-10-2005 01:19 PM
01:28 PM
