Tranny/Shifter Question answered... - Mustang Evolution
Old 05-07-2006, 12:24 PM   #1
Fast93Coupe's Avatar
Red face Tranny/Shifter Question answered...
I finally found out whats wrong with my tranny... I talked to a 5.0 man at auto zone, and got my answer. He told me the T-5 and T-45's have aluminum
clutch forks in the tranny, and over time slamming it into second or fourth the forks start to bend and in some cases they break. My second and fourth are so far back i have to hold it in gear, because the shifter hits the console.
He told me I should invest in another, and was wondering which one you all think i should invest in. I'm looking for at least a 600 horsepower capability.
---1993 Ford Mustang Lx Coupe-performane bolt ons, BBK Cold air intake, B&M Ripper shifter, King cobra clutch kit, Steeda adjustable clutch kit, basically stock...
*1994 Ford escort Lx- working on it
*1991 Mercury Grand Marquis- Dead...
*1995 Ford escort Lx- Parts car
----Cant find 'em, Grind 'em
Fast93Coupe is offline   Reply With Quote
Old 05-07-2006, 02:42 PM   #2
Re: Tranny/Shifter Question answered...
You're looking for another tranny? get a g-force t-5.
Old 05-07-2006, 03:40 PM   #3
I'm sorry about the error...I meant to say shift forks not clutch forks! The G-Force T-5 is exactly what I was looking at. Does it have the same problem the stock T-5 has? Such as the front bearing not staying lubed and starting to whine, etc. How reliable is it? I read its capable of 600hp which is a plus for me, and it only weighs 105lbs, any other info would be useful... preciate it!
Old 05-07-2006, 04:09 PM   #4
The g-force t-5 will handle anythin you can throw at it.
Old 05-07-2006, 05:26 PM   #5
Tbird232ci's Avatar
a T5 is a T5, you can only fix so many problems with it
Old 05-07-2006, 09:25 PM   #6
12second5.0's Avatar
Send a message via AIM to 12second5.0
Sounds like the shifter wasn't properly adjusted to allow the cracked shift fork.Yes it is common on abused T-5's
12second5.0 is offline   Reply With Quote
Old 05-08-2006, 03:53 PM   #7
t-56s seem to hold up good to power, but... they have crappy ratios on the ford spec. Go with a viper spec its a better made t-56 anyway. It may be costly... but it will get the job done unless you want to go auto.
Old 05-08-2006, 06:24 PM   #8
Send a message via AIM to lthlsnake
There is where i get all of my transmissions D&D Performance they are great to deal with and great customer service. I ordered my T56 from them and 2 days later it was here.
If i was going to put another tranny in it. I would go with the T56
http://i4.photobucket.com/albums/y10...33138qc2lh.jpg
539.1rwhp 585.2rwtq without n2o
lthlsnake is offline   Reply With Quote
Old 05-09-2006, 09:22 PM   #9
Thanks for the input, I love this site... I'v done some researching and still cant make up my mind between the Viper T-56, and the G-force T-5. Would the 6 speed allow you to have a better top speed because of the extra gear?
What makes the 6 speed better than the five... I have tons more q's but I'll stop there for now.
Old 05-09-2006, 09:56 PM   #10
You may have more top speed with the Viper spec trans providing that you have the horsepower to do it.If wind drag wasn't a factor then the answer would definately be yes.
Old 05-09-2006, 10:54 PM   #11
bbunt302's Avatar
A Viper Spec T-56 will handle a little more torque than the G-Force. However, the T-56 is also a good bit heavier. Also, the Viper T-56 will have a 6th gear ratio of .50, which is great for gas mileage on the interstate. It means you can throw in some 4.30 gears and still run a decent RPM going down the highway.
Personally, if I was building a mostly drag-oriented car, I would go with the G-Force, unless I was planning on making more (or right at) the recommended power level. For a nice street car, I'd rather have the T-56.
Scary stuff.
Old 05-10-2006, 09:00 AM   #12
That sixth gear is nice for highway cruising. My roommate's camaro with 3.73's does just over 1500 rpms at 70 mph.
Old 05-10-2006, 07:49 PM   #13
What do I need to set my car up for the viper spec T-56? I like the viper spec gear ratios better than the T-5.
Help posting and hopefully a question that can be answered. GhostStang New Member Introductions & Greetings 0 07-03-2009 09:59 PM
Simple shifter/tranny question USMCSS 1996-2004 Mustang GT 17 03-31-2007 05:24 PM
Tranny/Shifter problem... Fast93Coupe 1979-1995 Mustang GT 6 04-22-2006 03:26 PM
The Ultimate Question is FINALLY answered bluemustang The Bar 17 12-08-2004 12:19 PM
Friend wants a question answered... NJStang86 Pre-2005 V6 Mustang 5 09-07-2004 09:36 PM
06:06 AM
