Im so fed up... please help. - Mustang Evolution
Old 05-07-2006, 06:22 PM   #1
Zim
You want to **** me?
Zim's Avatar
It seems like I cant keep this POS running right for more than a week at a time. Here's the deal... My car seems to miss at high RPMs, or just while under WOT in general. So far Ive replaced the coil, cap, rotor, wires & plugs about 12k miles ago with autolite copper plugs. The wires are 8mm wires, nothing fancy. Ive had problems like this in the past and replaced the coil and it seemed to cure the problem for a while, now its back. I replaced the coil again and it didnt really help... so I need to figure out what the underlying problem is. I havnt changed anything on the car to make it start doing this, it just does. Timing is set at 13* i believe. What happens is when I just go straight to WOT, it feel like the car almost boggs, the tach will jump around, and it just wont feel right. Once I get into 3rd and 4th gear and take it up to 4500-5000 RPMs, the RPMs will skip real fast straight to 6k but it doesnt feel like im being "propelled" during that last 1k RPMs because it happens so quick. Its hard to describe, but thats the best I can do... anyone have anything they can suggest? Im so tired of all this crap constantly happening when I really take good care of the car with maintenance and everything. Please help.
I think tomorrow Ill try cleaning my TPS and MAF sensors just for piece of mind. Ive cleaned the MAF in the past 10k miles, but the TPS hanst been touched since I bought the car. TPS is on the throttle body correct? Can I clean it without actually removing it from the TB or does it need to be taken off? Tomorrow Im also going to pull the plugs and make sure they all look ok on the electrodes. Besides that, anyone have any other tips?
I like toys
Old 05-07-2006, 06:25 PM   #2
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Re: Im so fed up... please help.
im not sure... all i can say is check the plugs....but i dont know much so when u find out let me know so i will know the next time
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 05-07-2006, 07:13 PM   #3
johnpittbull's Avatar
Hey Zimstang. I assume you have a 5speed in the car, since its a Cobra. How many miles on it anyways? Why I ask, is that it might be your clutch telling you that it might be due to be changed. Just an idea to throw out there.
johnpittbull is offline   Reply With Quote
Old 05-07-2006, 07:21 PM   #4
Zim
Zim's Avatar
80k miles... but when I throw it in 4th or 5th driving around, and then get on it, it wont rev up real high, then catch and rev back down like a classic slipping clutch.
I like toys
Old 05-07-2006, 09:05 PM   #5
Thomas91169's Avatar
run some seafoam through it before changing the plugs out(cause after teh seafoam theyre more than likely going to be screwey anyways)
-Thomas-
Old 05-07-2006, 09:09 PM   #6
Welcome to my world Zim. Fix one thing... some other **** breaks.
Old 05-07-2006, 09:28 PM   #7
12second5.0's Avatar
Send a message via AIM to 12second5.0
So, is the car bucking when at these said rpms? Like the engine has a miss?
12second5.0 is offline   Reply With Quote
Old 05-07-2006, 09:30 PM   #8
Zim
Zim's Avatar
Yeah, seems like it anyway... the tach gets really jumpy and doesnt smoothly rev.
I like toys
Old 05-07-2006, 10:27 PM   #9
When my tach started acting up my TFI module was going out.I know your module is in a different location than mine but it could be the cause.
Old 05-07-2006, 10:29 PM   #10
Zim
Zim's Avatar
whats TFI stand for?
Also, its not just the tach... you can feel the engine struggling at certain points (or whatever it is struggling)
I like toys
Old 05-07-2006, 11:28 PM   #11
Justin's Avatar
may have something to do with the fuel...mine had a problem when it got to high rpms and i changed my fuel filter and i changed my pump too and havent had a problem
Old 05-07-2006, 11:49 PM   #12
Zim
Zim's Avatar
im getting a lot of people saying it might either be the clutch, a bad injector, failing fuel pump, or clogged filter. I changed the filter right when I got the car about a year ago. My little brother ran it bone dry of gas at one point, but I wouldnt think a filter that's as new as it is would fail because of that... plus it drove fine for a while, then just started doing this. How do i check for a bad injector or tell if my fuel pumps failing?
I like toys
Old 05-08-2006, 06:15 AM   #13
Thick film ignition
Old 05-08-2006, 08:36 AM   #14
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
my 96 was doing that i know its a different motor 4.6 but anyway it was my fuel pump was going out and wasn't giving engine the fuel it needed....might check that good luck
1996stang is offline   Reply With Quote
Old 05-08-2006, 08:53 AM   #15
If the Fuel pump is stock it is worth looking into.....
Old 05-08-2006, 09:34 AM   #16
DarkShadow's Avatar
Send a message via AIM to DarkShadow
That would expain why at WOT you start to have problems, the pump can't keep up with the demand. You don't have an excess of miles on it, but just the age will make it deteriorate. Before you do that however, run some Lucas fuel sys cleaner first. If you have a clogged injector that will clean those out and your problem is fixed without having to buy a $150 pump.
DarkShadow is offline   Reply With Quote
Old 05-08-2006, 10:15 AM   #17
get a wideband on a dyno see if the a/f is off
Old 05-08-2006, 10:26 AM   #18
I would get it dyno tuned first and then go from there... can see exactly what your fuel is doing like SpectorV said.
Old 05-08-2006, 10:35 AM   #19
Zim
Zim's Avatar
Ill probably end up changing the pump anyway since Ill be supercharging it this summer... Im thinking a 255lph will be plenty, and Ill run that fuel system cleaner too and see if that helps out. When changing a pump, all you do is unstrap the tank, drop it down... then what? Im getting low on gas, so Ill probably run it until Im scared its out of gas to keep things on the lighter side. I have a jack so Ill just lower it down using that. How do I make sure the filler tube doesnt get caught up when I lower the thing down?
I like toys
Old 05-08-2006, 10:36 AM   #20
bbunt302's Avatar
Sounds pretty fuel pumpish to me. Especially if you still have the stocker. I don't remember exactly how much power they will "support," but I can imagine it's struggling with the numbers you're putting out. Plus, this will be a good reason to go ahead and upgrade to a 255lph pump so you can hear the cool pump whine.
Of course, this is assuming you haven't already upgraded it. :dunno:
EDIT: Damn... just a little too slow.
Scary stuff.
Old 05-08-2006, 10:53 AM   #21
DarkShadow's Avatar
It has enough slack that it wont really get caught up. i would recommend making a 2 person job out of it even tho one can do it. Definately use a jack tho. My nail JUST grew out the giant purple splotch from where I dropped the tank on it.
Drop the tank. There will be a little porthole looking panel that you take screws out of to remove. Pull the pump harness up out of the tank. Disconnect the old bucket being careful with your little floaty, reconnect the new one, stuff it all back in, and re bolt it. You will also need to disconnect fuel and vent lines going from your fuel filler under the fuel door. Also be sure to depressurize the fuel sys and disconnect the battery.
It's best to get a Hayne's or Chilton's if you don't alreaady have one to make sure I didn't forget anything and it gives you cool little pics.
Old 05-08-2006, 10:57 AM   #22
Zim
Zim's Avatar
Yeah I just looked in my haynes manual... so I have that for reference. I need to figure out what pump I need to buy for a direct swap, I dont want it to not fit.
I like toys
Old 05-08-2006, 02:06 PM   #23
Justin's Avatar
it would help if u got a peice of wood to put on the jack to help support the tank...that what i did when i canged mine when i had the same problem
Old 05-08-2006, 02:08 PM   #24
Zim
Zim's Avatar
Yeah I plan on it... im gonna run a bottle of injector cleaner through it first to see if that helps me out at all.
I like toys
Old 05-08-2006, 02:09 PM   #25
Justin's Avatar
Lucas...best kind in my opinion
Old 05-08-2006, 02:13 PM   #26
i run injection cleaner every oil change~
Old 05-08-2006, 02:31 PM   #27
Danger Dude's Avatar
Have you changed your worn Distributor shaft on that 5.0. The distributor on those are notorious for giving problems. As they wear the rotor at the top of the shaft sometimes makes good contact with the distributor contact points and sometimes it does not. It would cause missing and uneven idle at times as well as cause loss of Hp and bog in higher rpms. It will aslo make the tach most erratic.
Easiest way to check it out is take the distributor cap off and see if there is any side to side play in the internal shaft on the distributor. Also the distributor contact points some will look worn and some wont
Old 05-08-2006, 02:41 PM   #28
Zim
Zim's Avatar
I havnt personally changed the dizzy shaft, no. I bought the car with a new motor in it, so Im assuming the dizzy was new at the time. The cap and rotor are maybe 6k miles old, so I dont think that would be the problem. Ill go check the dizzy and see if I can move that shaft.
I like toys
Old 05-08-2006, 02:44 PM   #29
Those shafts were of inferior metal.it seems to be the most problem on 94-95 5.0's. As the distributors were being replaced in the newer cars I think ford skimped at the end. I have had numerous people PM me asking why their rotors and caps are wearing out after a few thousand miles.
It also might not be the problem but without being at the car You problems that you describe sound like a bad distributor. There should be absolutely ZERO side play. You might have some minute up and down play but again not a lot
Old 05-08-2006, 02:49 PM   #30
Zim
Zim's Avatar
nope, the shafts fine....
I like toys
Old 05-08-2006, 03:41 PM   #31
Tbird232ci's Avatar
The pump you need is a Walbro GSS340. All of the companies like edelbrock, holley, BBK, and all use a Walbro pump.
Walbro Ford High Performance Fuel Pump/Kit
So far, thats the cheapest place ive found for them. Thats the pump i have in my car, and it supports 22psi easily. Its all quiet, cant tell its aftermarket
You put a fuel pressure gauge on it? One that you can monitor while youre driving?
Old 05-08-2006, 04:13 PM   #32
bbunt302's Avatar
Your Walbro is quiet? Mine's ridiculously loud. It could have something to do with the fact that all the sound deadener has been gutted out of the car too though.
Scary stuff.
Old 05-08-2006, 04:18 PM   #33
Zim
Zim's Avatar
Just replaced the fuel filter and had the injectors cleaned... didnt help. It only happens under a heavy load such as WOT. I took it up almost to redline without gettin on it hard and it never happened. Only things I can think of now are fuel pump, wires, or plugs. I highly doubt the dizzy's bad...
I like toys
Old 05-08-2006, 04:21 PM   #34
Tbird232ci's Avatar
I could do that in my TC when the pump died, took it up to redline, but not under WOT, and no problem, get under any boost, and it would act up.
Old 05-08-2006, 05:49 PM   #35
Did you check the rotation of the shaft point to the magnetic pickup. If there is a gap you will have intermittent spark to the rotor
pffft....fed up! ChickStang02 Mustang Audio & Video 31 04-30-2007 04:56 PM
K-FED superbowl commercial leaked LOL Zim Pictures and Videos 13 02-02-2007 08:51 AM
K-Fed may get his revenge.. a K-Fed/Britney Sex Tape May Exist Brent The Bar 35 11-14-2006 01:06 PM
OK, Now im really ****ing fed up Thomas91169 The Bar 14 06-27-2006 01:45 AM
09:49 AM
