HELP! Tuning 347 gt 5.0?? - Mustang Evolution
Old 05-11-2006, 07:41 PM   #1
Hey guys, hopefully you can help me out...my buddy has a 94 GT with a 347 in it...the car isn't driveable, is there any chip/injector combo or programs, or any website or tuning sites you can direct me to? Suppsoly the car ran well before, but now with the new engine build it doesnt' run well at all.
Thanks
Chris
the yoda is offline   Reply With Quote
Old 05-11-2006, 07:58 PM   #2
bbunt302's Avatar
Re: HELP! Tuning 347 gt 5.0??
He really needs to take it somewhere to have it tuned on a dyno. That's the only way he'll really get a decent tune out of it.
If you'll tell us the general area of where he lives, we may be able to direct you to a tuner.
Scary stuff.
Old 05-11-2006, 08:33 PM   #3
we live in Lexington, VA...which is around nothing, we just had a dyno open up around here, but i doubt anywhere local that can tune it.....but is there any companies in NC/MD/VA that can do it? I'm sure he doens't mind bringingin it somewhere and driving a lil bit...
Old 05-11-2006, 08:57 PM   #4
bbunt302's Avatar
I'm sure there are. I don't know of any personally, but maybe someone else will chime in.
Scary stuff.
Old 05-12-2006, 12:00 PM   #5
so you are telling me there is no place on the net where i can just buy a chip for 30lb or 42lb injecoters for this car? There has to be something out there. Is there any tuning shops online or webistes i can contact?
I'm going to add a list he gave to me as well
GT Ecu
347 Stroker
224/232 Duration, 555/565 Lift
Trick Flow Track heat heads
Trick Flow Track Heat Inakes.
Of course he could just put a carb on it...which would be better? I assume if he can't get a tune for this car, he will put a carb. on it..
-Chris
Old 05-12-2006, 01:58 PM   #6
bbunt302's Avatar
With modifications that extensive, he will need a custom dyno tune with wideband O2 sensors to get the correct air/fuel ratio.
You can get it to run with the stock ECU, but getting it to run efficiently is a whole other issue. First of all, is he running 30# or 42# injectors? With that combo 30# injectors should be plenty. With 42# injectors, he'll have a hard time getting it do anything but run rich, even if he turns the fuel pressure down with an adjustable fuel pressure regulator (which he should also have). I also assume he has a mass air meter that is calibrated for whichever injector size he has? If not... there's the problem right there.
Also, what exactly do you mean by not running well? Is it missing, dies at idle, just isn't making power???
Scary stuff.
Old 05-12-2006, 08:04 PM   #7
Zim
You want to **** me?
Zim's Avatar
Yes, our sponsor VMPtuning can help you out... CHeck out their website
VMP Tuning Inc
I like toys
Old 05-21-2006, 12:32 AM   #8
Bbunt302 is right! The car will need to be tuned with a wideband by someone knowledgable and def. make sure the air meter is calibrated to the injectors! The stock ecu is not capable of running well w/ those mods! Also be sure to check all your vacuum lines for leaks! Prob. not the issue but I've seen it before! The car may not run well but it should still RUN! This is the best advise I can give you!
snake99bite is offline   Reply With Quote
331 vs. 347 Powerboat 1979-1995 Mustang GT 12 03-14-2009 11:47 AM
1992 Lx Hatch 347 Spark Plug Mustangs for Sale and Wanted 2 07-17-2008 11:17 PM
More pics of my 347 blow up! 91GTstroked Pictures and Videos 28 01-28-2007 02:06 AM
347 stroker powerhungry966 1979-1995 Mustang GT 10 10-12-2006 08:52 PM
347 stroked mustang..... midnightmustang 1979-1995 Mustang GT 10 08-15-2004 02:40 PM
07:39 PM
