Yes i asking this, how do you properly re-oil a filter? - Mustang Evolution
Old 05-13-2006, 03:51 PM   #1
I decieded to clean my filter today(57 Series FIPK) and i followed K&N instructions but they arent very good in my opinion. It says just to spray the "crown" of the filter. Should i be lightly spraying the whole filter(outside) a couple of times? Cause the rest of the filter is still a whitish color. I noticed another problem too. I followed their instructions and put the filter back on to test it out and now it idles rough(well the rpm goes up and down, plus the volts too) and like "dies" 95% of the time if dont apply any pressure to the gas. Anyone know whats up? Its to do with the filter right?
Thanks
Anyone know if AEM makes those oil-less filters for mustangs? I couldnt really find anything.
Jrw4482 is offline   Reply With Quote
Old 05-13-2006, 04:36 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Yes i asking this, how do you properly re-oil a filter?
The reason your car is dying is most likely because you oiled it too much, and that oil is now on your MAF sensor. Get some electrical cleaner and spray the MAF sensors and your car should idle better. Im pretty sure there are oilless filters out there beyond just a paper filter, but honestly paper filters arent THAT bad...
Good luck.
I like toys
Old 05-13-2006, 05:26 PM   #3
Good luck.
Ok thanks. Ive never used electrical cleaner before for this. Is this what i do? I disconnect the the sensor from the meter? or do i also spray the meter and the tube and all?? Or what do i do? I dont have much experience around cars.
Old 05-13-2006, 08:09 PM   #4
you basically remove the filter, brush it out with a fine paint brush (not stiff, but soft~) and then run water from the inside out to remove any dirt. Use the cleaner and then rinse it off again really good as per the instructions. When reoiling dont go crazy use a modest amount it does not need a ton.
Once installed drive the car a day then take some on contact NO RESIDUE electronic parts cleaner and clearn your MAF sensor. Then a couple weeks later do this again. You will be good to go after this.
Old 05-13-2006, 08:34 PM   #5
Danger Dude's Avatar
Once installed drive the car a day then take some on contact NON RESIDUE electronic parts cleaner and clearn your MAF sensor. Then a couple weeks later do this again. You will be good to go after this.
READ WHAT HE SAID!!!! NON RESIDUE CONTACT CLEANER or PARTS CLEANER. IF you use regular contact cleaner or parts cleaner you will only make matters worse or even destroy the sensor in the MAF
Old 05-14-2006, 12:16 AM   #6
When cleaning a K&N filter, I recommend setting aside a few hours. I take mine, spray the cleaner agent on there, let it sit for about 15 minutes, then run a light stream of water over the whole thing, ensuring I get all the mess out. Let it dry overnight, then spray it down with the oil. I dunno what kind of oil you have, but mine came in an aerosol can, I sprayed the filter until it was an even shade of red/pink. Gonna clean my maf when I get home with some non contact cleaner, and call it done.
Old 05-14-2006, 08:13 AM   #7
MonteCitan's Avatar
still need to clean the MAF a few times after doing this as described above, but I've found there's fewer issues if you put the oiled filter in an old pillowcase
and sling it around.. you'd be surprised how much excess oil comes off
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-14-2006, 09:09 AM   #8
Thanks all.
I dont know if the contact cleaner i bought is non residue. Its Lloyds electrical contact cleaner, it says on the can it can be used on electrical motor parts. I bought it a parts store so i would think that it would be safe right??
This is the only info on a site i could find, Lloyds Industrial
(its the flammable one)
Anyone have any experience with this stuff
Thanks all.
Old 05-14-2006, 11:18 AM   #9
the bottle I picked up at autozone said no residue on it.
Old 05-14-2006, 12:08 PM   #10
Zim
Zim's Avatar
To answer that question, just spray the cleaner inside the MAF. If you look in there, youll be able to see where that sensor is. DONT TOUCH THOSE SENSORS. THeyre very very fragile... just spray the cleaner on them and you should be good to go.
I like toys
Old 05-14-2006, 01:00 PM   #11
Thanks all.
Thanks all.
If it does not say Non Residue cleaner you have to assume it is not and go to Autozone or Advance and pick up a can of Non residue contact cleaner.The Advance brand Non-Residue Contact cleaner is less that $3.00 for a big can
Old 05-14-2006, 06:42 PM   #12
Ya, i live in Canada, we dont autozone or advance, but i found some.
thanks for the help all.
Old 05-14-2006, 06:47 PM   #13
if you have a cold air kit its very easy to clean one, you just buy the tamper proof torx bits from where ever and remove the maf sensor, just be very careful pulling it out or putting it in so you dont bend the wires~
what do you need to lower properly 1996v6stang Pre-2005 V6 Mustang 8 07-29-2010 08:01 PM
overheating after changing the oil filter adapter 2003stangmachI 1996-2004 Mustang GT 8 10-29-2009 09:26 AM
oil in air filter housing midnightrider_s Pre-2005 V6 Mustang 9 10-04-2009 08:19 AM
which oil filter upton7 1996-2004 Mustang GT 17 04-13-2009 05:05 PM
03:38 PM
