heads - Mustang Evolution
Old 05-17-2006, 08:03 PM   #1
heads
Dart Pro 1 Vs. Trick Flow Twisted Wedge
I got a 93 mustang gt
93stanger is offline   Reply With Quote
Old 05-17-2006, 08:21 PM   #2
bbunt302's Avatar
Re: heads
I'd say the Trick Flows. They're probably the best head in their price range for a 5.0. Of course, I'd really recommend you save a little extra for the AFR 165s...
Scary stuff.
Old 05-17-2006, 08:22 PM   #3
Re: heads
+1
Based on the write up in 5.0 a few months ago about the AFR heads on a 5.0....get a few extra bucks and get those...I don't remember if the 185s were that much better than the 165s....but either way, that would be the better route.
Old 05-17-2006, 08:40 PM   #4
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: heads
AFR's are a good head no doubt.The only thing is you need to upgrade the springs I believe so you are out $1400 to 1500 on a set of heads vs. Trick flow or Edelbrock's which are great out of the box and within 10 horsepower on a stock bolt on 302.They are usually around $1100........
12second5.0 is offline   Reply With Quote
Old 05-17-2006, 09:32 PM   #5
Zim
You want to **** me?
Zim's Avatar
Re: heads
Not "technically" a poweradder... moving to the 5.0 forum.
Id do TF if you're looking for out of the box. AFR's are real nice, but as mentioned, youll need new springs.
I like toys
Old 05-18-2006, 07:35 AM   #6
bbunt302's Avatar
Re: heads
The new springs aren't a total necessity depending on the cam you are planning on running though. Sure, they are a nice and upgrade and definitely recommended for anything beyond a mild cam. But I'm running a Comp Xtreme Energy 270HR cam in mine with the original AFR springs with no problem. Like I said though, it's a quite mild cam (only has .512" lift) and I don't take the car up to 6k RPMs everywhere I go.
However, whenever I end up buying a coupe to put that motor in, it's gonna get new springs and a custom cam from FTI.
Scary stuff.
Old 05-18-2006, 10:56 AM   #7
Zim
Zim's Avatar
Re: heads
My ported GT40s with the e303 cam are rockin trickflow valve springs
If I ever buy new heads, itll be afr 165's and ill just swap these springs over.
I like toys
Old 05-18-2006, 11:06 AM   #8
Danger Dude's Avatar
Re: heads
OK I am going to throw my 25 years of engine building experience around and disagree with my fine friends here. Never do a engine build of any type when including a cam change and use stock springs or valvetrain hardware. 90% of all modded engines break do to overlooking the valvetrain. So the little more you will spend on new springs and hardware is valuable insurance. Cause of a spring breaks and the keeper comes off you will lose at the very least a Piston and a head but you could destroy the block in the process.
On of the reasons is spring steel is subjected to high temp and cool down as well as a constant lift in a stock engine. Steel tempers to the lift and the heat. When you change the lift and the heat characteristics of a engine you change the spring movement and temp it works in. This change to the lift can actually cause what would appear to be a spring in good shape to break. You have to remember one valve travels up and down 1,008,000
in a 6 hour period at 2800 rpms at roughly 75mph on the highway which means that spring is compressed and contracted 1,008,000 time in that 6 hours now think about what they is in a years time
Old 05-18-2006, 12:14 PM   #9
bbunt302's Avatar
Re: heads
They weren't stock springs. They were the "stock springs" that come with the AFR 165 heads. Everyone recommends to go ahead and upgrade them to an even better spring, but they are a large improvement over the factory Ford springs.
Scary stuff.
Old 05-18-2006, 01:02 PM   #10
Re: heads
What I am trying to point out is even if you have performance heads and springs on a car for a few years and you decide to get a more agressive cam with a different lift you need to really consider new springs and keepers.
Old 05-18-2006, 02:52 PM   #11
bbunt302's Avatar
Re: heads
Definitely. When I do take the motor out of the car, the heads are gonna be completely re-worked. I may even go ahead and bore out to a 306 and do a complete bottom end rebuild while I'm at it, but I haven't decided yet...
Also, here's a little description of the springs that came with the AFR heads: "1.450" OD Hydraulic Dual Valve Spring w/ dampener, 120 lbs on seat, .550" maximum lift". I'm well under the maximum recommended lift and shift just before 6,000 RPM, which is probably why I haven't had any problems from them. Their website recommends an upgrade if you are gonna be seeing higher than 6k RPM due to valve float.
Scary stuff.
Old 05-23-2006, 04:34 PM   #12
Re: heads
Go w/ afr's! they're a little more $ but def. woth it!
snake99bite is offline   Reply With Quote
Old 05-24-2006, 08:05 PM   #13
MonteCitan's Avatar
Re: heads
ditto 'cept on cam.. and my ported GT heads.. (just stamped GT lol.. 93 cobra heads..) with 1.7 RRs and trickflow springs are supporting high 11 second runs on a mere 331 bottom end
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
heads 05+ 4.0L V6 2007STANG Mustang Parts for Sale and Wanted 1 07-22-2009 12:02 AM
PI heads jk7208 1996-2004 Mustang GT 3 07-07-2009 07:04 PM
heads johnnyc 1996-2004 Mustang GT 1 06-08-2009 06:29 PM
need help with heads johnnyc 1996-2004 Mustang GT 2 06-08-2009 01:15 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
09:02 PM
