gears officially go in - Page 2 - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 01-04-2007, 05:04 PM   #36
rocknbronco's Avatar
rocknbronco is unknown around these parts
Re: gears officially go in
if you really wanted to be anal you should drive the car (EASY) until the gears in the back get hot and then let it cool off for about an hour, do this a few times and you should be good. I would change the fluid and inspect it to see if you have any major issues with metal comming off.
X2
rocknbronco is offline
Old 01-04-2007, 08:57 PM   #37
modular2valve is unknown around these parts
Originally Posted by bbunt302 View Post
Break-In
Any overloading or overheating will cause the oil to break down and the ring gear and pinion will fail. A ring gear and pinion installation, especially a high numeric ratio with new bearings, can cause an excessive heat build up in the rear end and cause softening of the gear teeth and bearings if a break-in is not performed.
Break-in Procedure - All vehicles and all applications:
To break-in the installation, perform a run-in prior to driving with the rear wheels jacked up, operating at idle speed in high gear for a minimum of five (5) minutes. Then drive the vehicle 10 miles at a normal speed, let cool for one (1) hour and then repeat entire process again.
Notes for Special Use Vehicles:
Vehicles used for Towing:
Vehicles used for towing need approximately 200 - 300 miles of normal street driving before being used for towing.
Circle track race cars:
Make approximately 6 - 8 laps at slow speed, then let cool for 30 minutes, make 6 -8 laps more at slow speed, then 2 -3 laps at full speed, let cool again for 30 minutes.
Drag cars:
Drag cars need only an initial run-in since they are driven short distances and heat is not normally a problem with proper lubrication and backlash allowances.
thats what i do too...worked fine everytime.
96 GT- Who knows what's in it.
modular2valve is offline
Old 01-04-2007, 09:46 PM   #38
Justin's Avatar
Justin is unknown around these parts
Send a message via AIM to Justin Send a message via Yahoo to Justin
So when they get done i should drive for 10 mins... then let it cool down then drive it again for ten mins and im done?
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline
Old 01-04-2007, 11:01 PM   #39
thats what you wanna do
Old 01-16-2007, 02:11 PM   #40
Justin's Avatar
gears are in and holy **** it made a diffrence....only thing is i have to manually shift it till i can get a programed for them and get a speed calib
Justin is offline
Old 01-16-2007, 02:18 PM   #41
Hey I would like that more myself glad your happy with em.
Old 01-30-2007, 03:03 PM   #42
Justin's Avatar
4.10s are in
Speedo Calib is in
Now how or what should i do to help firm up my shift points. or do yall have any suggestions on what i should do next?
Justin is offline
Old 01-30-2007, 03:06 PM   #43
bluemustang's Avatar
bluemustang is unknown around these parts
Originally Posted by Justin View Post
4.10s are in
Speedo Calib is in
Get a Shift Kit
bluemustang is offline
Old 01-30-2007, 03:10 PM   #44
Justin's Avatar
I have a shift kit...not sure what kind.. was in the car before i got it.... I believe he said a valve body s/k
Justin is offline
Old 01-31-2007, 10:01 AM   #45
Only other way i know of making shift points firmer is threw a chip
Old 01-31-2007, 11:26 AM   #46
Justin's Avatar
i will prolly get one when i go to BR to meet up with Rob Gabe and Kyle
Justin is offline
Closed Thread
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
I have officially seen it all: MarkuzLS1 General Car Discussion 10 12-27-2007 09:46 PM
well, my stang is now officially... dark The Bar 12 09-20-2004 08:24 AM
4.10s are officially in!! tire The Bar 5 07-14-2003 11:50 PM
10:50 AM
